2008 honda crv AC diagnosis
- toolanddie
7 years 3 months ago #31857
by toolanddie
2008 honda crv AC diagnosis was created by toolanddie
I do not have power at the compressor. I checked these things thus far: static pressure (ok); jumped #30 W slot in fuse box- have power than at compressor at the 3 pin plug when disconnected; both fans come on when AC is turned on; swapped relay with another identical relay in the fuse box. But when I put a known good relay in, I have no power at the compressor plug when disconnected. Please help me diagnose this problem. Thx.- Hans.
7 years 3 months ago #31865
Replied by Chad on topic 2008 honda crv AC diagnosis
Check fuse 36.
With the relay pulled, and the key ON, you should have battery voltage on TWO of the relay "slots".
- toolanddie
7 years 3 months ago #31876
by toolanddie
Replied by toolanddie on topic 2008 honda crv AC diagnosis
I checked for power at those pin slots. but what I did wrong was I had the 3-pin connector unplugged while checking for power at the compressor. I should have kept the connector plugged in while then back probing to check for power at the compressor. So that told me the thermal protector plays a part in making the electrical series complete. I need clutch assembly or a new compressor assembly. I will install a new clutch assembly first, way cheaper than replacing the compressor assembly. And see what happens from there. Still might need a new compressor. Thx. Chad for the info! Hans.
