Code 0340 Camshaft position sensor bank 1
  • TG53
  • TG53's Avatar Topic Author
6 years 7 months ago #38825 by TG53
I'm getting several codes but thought I would start with this one. Code 0340 Camshaft position sensor bank 1. I know very little about automotive electronics and using multi-meters on them but was wondering if someone could tell me how to test my camshaft position sensor and wiring using an AstroAI DM6000AR multi-meter? I have attached a picture of the meter. Just a little extra info, I am using the chassis, drive train, and electrical system from a 2008 Ford sport trac to build a 1953 truck. All of the wiring was removed and reinstalled during the build. I pretty sure I have grounded everything but there is a chance this could be a ground problem as I have several codes to chase down that weren't there before removing the wiring from the sport trac.
Thanks for any help!
6 years 7 months ago #38842 by gav09
Replied by gav09 on topic Code 0340 Camshaft position sensor bank 1
which motor? You can ohm out the sensor and the wiring. You can also measure the ac voltage of the sensor. other than that a scope would be needed
6 years 7 months ago #38843 by John Curtis
Replied by John Curtis on topic Code 0340 Camshaft position sensor bank 1
Make note of all the codes, clear them and see which ones come back. If you list all the codes it could help.
You can use a volt meter and turn the engine over slowly by hand and see if you get any change whatsoever. If you go slow enough you should see a noticeable voltage difference.
  • TG53
6 years 7 months ago #38848 by TG53
It is a 4.6L.
