[FIXED] ABS BIAS VOLTAGE
- Richey.brown
- Thank you received: 6
I will let you know when we finally change the ABS module if it fixes the problem.
The ONLY other thing I can think of is some kind of resistive short at the ABS module connector itself. I'm thinking of green corrosion between the wheel speed sensor pin and a neighboring pin that happens to ground when the brake pedal is applied. I know, it's kinda a stretch, just thinking out loud.
- Richey.brown
In the end it was obvious when I eventually pulled the ABS module connector.
I
Andy, Welcome Back!Andy.MacFadyen wrote: I have seen an MG ZT with corroded connector on the Bosch ABS pump-module, I had not disimilar symptoms I didn't have any scantool at the time that would read the system but had to go the voltmeter and scope route.
I
That's about the only scenario I could imagine apart from a faulty module.
- Richey.brown
- Richey.brown
- steve
- Thank you received: 17
Richey.brown wrote: Customer finally caved in and brought back car for repair. Sent ABS pump off for test and repair. They confirmed fault and repaired. It was turned around in 3 days with a happy customer at the end of it.
Whoa, fix outta nowhere! :woohoo: Five months later, that's gotta be some kind of record around here. Well done!
Honest question: In the UK and Europe, is it more common to send modules like this out for repair, rather than replacing them? Similar services exist in the States, of course, but the vast majority of shops in my area would opt for replacement in the same situation. Not that there's anything wrong with module repair, just curious if there's a different attitude towards it?
