1993 302 5.0 f150 starting problem
  • Josh3089
  • Josh3089's Avatar Topic Author
7 years 8 months ago #27511 by Josh3089
1993 302 5.0 f150 starting problem was created by Josh3089
I have a 1993 f150 5.0 have changed the distributor spark plugs ignition control module ignition switch timing is correct coil is good pulling spout doesn't work and fuel shut off switch is good has spark and fuel running out of ideas to try
7 years 8 months ago #27513 by wacoeagle
Replied by wacoeagle on topic 1993 302 5.0 f150 starting problem
check your emmissions system, make sure EGR is not shot. when you say you have spark do you have sparks to all plugs? how did you determine you have fuel? if yo have spark and fuel the only thing missing is compression and air. can u be more specific, whats happening when cranking, is it poping backfiring, nothing at all, was it running good recently, do you have any codes. ?
7 years 8 months ago #27515 by wacoeagle
why did u cchange the distributor? not knowing your mechanical aptitude, my number one suspect would be distributor not in properly (even the best miss)< or 2 a chinese aftermarket that was junk out of the box.. LOTS of mr changs parts no worky good on these old trucks..
  • Josh3089
7 years 8 months ago #27527 by Josh3089
Replied by Josh3089 on topic 1993 302 5.0 f150 starting problem
Will do nothing just cranks no backfire or nothing even on starting fluid compression is good and only changed distributor because we tested for power coming out of the distributor and had no power coming out of it and yes spark to all plugs and fuel at the fuel rail and in the cylinders
  • Josh3089
7 years 8 months ago #27528 by Josh3089
Yes was running one day went out to start it the next day and just cranked
7 years 8 months ago #27531 by wacoeagle
take valve cover off and see if valves are moving up and down by looking at rocker arms. check for compression at cylinders.
7 years 8 months ago #27532 by wacoeagle
if u have compression you may have a crankshaft or camshaft position sensor went out, can you scan it for codes?
7 years 8 months ago #27533 by wacoeagle
if crank or camshaft position sensor is bad, could be firing but at wrong time, intermittent firing, ect.
  • Josh3089
7 years 8 months ago #27544 by Josh3089
It's a 93 the crankshaft position sensor is the pickup coil in the distributor and I have put a new duralast gold distributor in and compression is good and it doesn't fire at all it doesn't even fire on starting fluid
7 years 8 months ago - 7 years 8 months ago #27547 by wacoeagle
in your initial post you said it had no spark? when you say fire do you mean start?
Last edit: 7 years 8 months ago by wacoeagle.
7 years 8 months ago #27548 by wacoeagle
sometimes ignition wont pop if fuel isnt there, do you hear the fuel pump whirrr when you turn the key to run? open gas cap or have someone help listen or turn key for you. fuel pump fuse... if no whirrr, maybe fuel pump relay. when you try to start it see if your getting voltage to your coil
7 years 8 months ago #27549 by wacoeagle
yes or no. are the SPARK PLUGS SPARKING when crank the engine over.
  • Josh3089
7 years 8 months ago #27551 by Josh3089
The initial post said it has spark yes the plugs spark when it cranks and yes the fuel pump runs on both tanks
7 years 8 months ago #27558 by wacoeagle
I would pull the distributor cap and make sure the wires from the signal coil are plugged in good, make sure all connectors are plugged in snugly . it sounds like a timing problem. if your gettng spark, and you have compression, if it is firing at the correct time, it has to run,. are you 100 PERCENT positive the distributor was put in correctly, can you verify . pull number 1 plug and pull valve cover off, bump it till piston gets to tdc, and rotor is pointing to number one plug wire, make sure both valves on number one are closed.
7 years 8 months ago #27560 by wacoeagle
also how did you time the new distributor?
7 years 8 months ago #27561 by wacoeagle
on chevys there is a wire that must be unplugged when u set base timing, then you plug the wire back in, and computer takes over. not sure if Ford uses same system.. its called a bypass ignition system on chevys.
scanner danner has some good vids on you tube abt ignition systems.
  • Josh3089
7 years 8 months ago #27563 by Josh3089
We put the number 1 cylinder to tdc and pulled the distributor and put the new one in in the same exact spot it's not a timing issue and it doesn't fire or backfire can I get someone else to answer possibly because at this point I have repeated myself a few times and your still going to conclusions that we have already checked
7 years 8 months ago #27565 by wacoeagle
last reply.. IT CAN STILL BE INSTALLED 180 degrees off if you didnt verify if the cam was on its compression or exhaust stroke, the eng reaches TDC TWICE in a cycle.
how did you verify it was at TDC on the compression stroke? also you cant just put a new distributor in just like the old one was and expect it to be right.. you need a timing light. go see autozone for the rent a tool program..
If you have spark which you say you do at the spark plugs (every one), if you have compression , which you say you do,, (all cylinders, ), and sprayed some starting fluid as you said you did, it has NO CHOICE but to run if it is in correct timing .
Yet you insist you do not have a timing problem because it took you forever to get the distributor back in., listen ive been there, good luck!!!
7 years 8 months ago #27566 by wacoeagle
when they are 180 out the motor wont even fart!!!!
7 years 8 months ago #27577 by guafa
Replied by guafa on topic 1993 302 5.0 f150 starting problem
Have you checked back pressure? When nothing works and i'm lost, that is the last thing i do.
Time to create page: 0.359 seconds
