1993 Ranger 2.3 5sp 2wd
  • Bear76
  • Bear76's Avatar Topic Author
7 years 4 months ago #31339 by Bear76
1993 Ranger 2.3 5sp 2wd was created by Bear76
My ranger is having issues. After running for about 15-30 minutes, it starts to hesitate and stumble under load at about 3k rpm. It progressively gets worse until it’s useless at any rpm under load. If I put it in neutral it will idle ok. I’ve been able to limp home and the next day it will start and run strong for about 15-30 minutes and it all goes downhill again. I have no codes and the check engine light doesn’t come on. I’ve checked all grounds, tested all sensors, and fuel pressure. I’m stumped. Any ides? Thanks
7 years 4 months ago #31340 by Cheryl
Replied by Cheryl on topic 1993 Ranger 2.3 5sp 2wd
Check for a restricted converter?
  • Bear76
7 years 4 months ago #31341 by Bear76
Replied by Bear76 on topic 1993 Ranger 2.3 5sp 2wd
I did. I found that the insides shattered. I replaced it but no change. I even ran without one for a bit while waiting for a replacement, no change.
7 years 4 months ago #31345 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 1993 Ranger 2.3 5sp 2wd
Is the issue worse on hot days ?
  • Bear76
7 years 4 months ago #31352 by Bear76
I don’t think external air temp is making it worse but it’s summer right now.
7 years 4 months ago #31357 by jreardon
Replied by jreardon on topic 1993 Ranger 2.3 5sp 2wd
Try unplugging the spout connector. When you do this you'll lost spark advance but see if it still stumbles.
  • Bear76
7 years 4 months ago #31358 by Bear76
I’ll try this today.
  • Bear76
7 years 4 months ago #31359 by Bear76
Ok, tried it. It didn’t change anything.
7 years 4 months ago #31361 by jreardon
Could this be EGR? Make sure you don't have vacuum to your EGR when it's acting up.
  • Bear76
7 years 4 months ago #31362 by Bear76
I’m going down this road too. How do I check the egr vac while driving? It only happens while under load, it will rev fine once out of gear. I had it on stands and put it in gear and it’s fine
7 years 4 months ago #31364 by jreardon
Just leave the vacuum hose to EGR unplugged and pinched so the EGR valve will stay shut when computer wants to open it.
  • Bear76
7 years 4 months ago #31416 by Bear76
Ok, did this and no change. I’m going to pull the bed and check the fuel pump. The pressure checks fine but I haven’t tried when it’s hot. I’ll check the grounds volts and pressure hot.
7 years 4 months ago #31418 by Cheryl
When you said you ran it without a converter you mean the converter removed? Or everything from the converter removed including the converter? Is it possible a chunk of the old converter went downstream and is causing a restriction?? I’d still suggest having a back pressure tester hooked up and drive it til it messes up and see if the gauge registers anything.
7 years 4 months ago #31419 by Cheryl
And monitor fuel pressure at the same time. No need to pull the bed off
  • Bear76
7 years 4 months ago #31420 by Bear76
I completely removed the converter and put in a test pipe. I fished out all of the matrix that made it downstream. I have since installed a new CC. Still the same issues. I’d rather remove the bed than work on my back plus I can run test leads from the fuel pump into the cab and test the voltage real time when it starts bogging down.
7 years 4 months ago #31422 by Cheryl
Good idea about voltage checking. Not to sound stupid or anything you sure the brakes aren’t sticking? It’s hard to diagnose when not actually there. Does that year not have a schrader valve on the fuel rail?? Do you have an off 1 scanner? If not maybe run jumper leads from the o2 sensor and monitor voltage. Again no offense we are not there to actually see what’s happening
  • Bear76
7 years 4 months ago #31424 by Bear76
It has an OBD1 ecu. I have a reader but it doesn’t show any codes. I’ve tested the o2 sensor and it checked out fine. The brakes don’t seem to be locking, I’ve had to push it out of the road a couple of times. Yes there is a schrader valve and the pressure is good but I haven’t set up a rig to test it while I’m driving.
7 years 4 months ago #31440 by tim.smith1
Replied by tim.smith1 on topic 1993 Ranger 2.3 5sp 2wd
Does your scanner have data stream? If so monitor the upstream o2 sensors to see if it is running rich or lean when the problem occurs that may help confirm if it is a fuel issue or an ignition issue.
  • Bear76
7 years 3 months ago #31454 by Bear76
No data stream.
  • Bear76
7 years 3 months ago #31599 by Bear76
I hooked up a fuel Pressure gauge and drove around until it started acting up again. The pressure was good ruling out the fuel pump. Aside from pulling the harness out and checking every inch, any other ideas?
Time to create page: 0.371 seconds
