Vw tdi t5
- mfrr_86
7 years 2 months ago #33117
by mfrr_86
Vw tdi t5 was created by mfrr_86
Hi im have vw t5 2.5l tdi axd engin code I'm have problem in ingictor 5 misfire I'm change ingictor and camshaft the code error p0305
- Desmond6004
7 years 2 months ago - 7 years 2 months ago #33124
by Desmond6004
Replied by Desmond6004 on topic Vw tdi t5
Does the injector need to be coded?.
Last edit: 7 years 2 months ago by Desmond6004.
- Vw mike
7 years 2 months ago #33142
by Vw mike
Replied by Vw mike on topic Vw tdi t5
I know it is not easy but I would suggest doing a. Compression Test May have broken valve springs.
7 years 2 months ago - 7 years 2 months ago #33313
Replied by Andy.MacFadyen on topic Vw tdi t5
A lot depend on what equipment you have a pro level scantool on most German diesels live data will give you an intake air grams/stroke reading for each cylinder that can help spot a valve or blocked intake port issue.
The main suspect though is going to be a compression issue, diesels need at least 300ps/22bar for a cylinder to fire without a misfire.
Basic checks on power to the injector but beyond that you would need a scope.
It is of course possible you have a bad replacrment injector. Only way to tell would be swap it to another cylinder
Last edit: 7 years 2 months ago by Andy.MacFadyen.
