Valve spring compression after torquing?
  • Donnyten
  • Donnyten's Avatar Topic Author
9 years 9 months ago - 9 years 9 months ago #5009 by Donnyten
Got around to reinstalling the cylinder heads and torquing the rocker arm bolts. I noticed on the front cylinder two of the springs seem more compressed than others. Could this potentially be due to weak Springs or is there something else that I'm missing.? On rear cylinder head all Springs are compressed equally after torquing. .gonna put the rest on hold for now until i can gwt some peace of mind
Last edit: 9 years 9 months ago by Donnyten.
9 years 9 months ago #5015 by matt.white
Replied by matt.white on topic Valve spring compression after torquing?
No idea what engine man but a few guesses would be weak springs, tight tappers, pumped up lifters or even just that cylinder is 'on the rock' and it's normal. Reallly need more info.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 9 months ago #5019 by Dylan
Replied by Dylan on topic Valve spring compression after torquing?
Agree with Matt. Some more info on this engine would help. Any chance you can post pictures?
  • Donnyten
9 years 9 months ago #5033 by Donnyten
Replied by Donnyten on topic Valve spring compression after torquing?
Might can't tell but the left spring is more compressed than the right one. it's only really like that for the front cylinder head. We are cylinder head offsprings look normal. It's one of 3.1 General Motors engine
  • Donnyten
9 years 9 months ago #5034 by Donnyten
Edit: pictures bad. I think ill just reassemble amd see how it goes. Can't really afford to put anymore money into this thing anyway
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
9 years 9 months ago #5041 by Ro-longo
Replied by Ro-longo on topic Valve spring compression after torquing?
If the lobe on the camshaft is on the high spot it will be trying to open that valve causing the valve spring to compress. Rotate the engine and watch that valve spring to see if it returns to normal height with the valve closed.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 9 months ago #5043 by Dylan
See what you mean. Looks kinda weird :huh:
Like Rob said, how does it look when you turn the engine over and both valves are closed...
9 years 9 months ago - 9 years 9 months ago #5049 by Tyler
Replied by Tyler on topic Valve spring compression after torquing?
Dylan wrote: See what you mean. Looks kinda weird :huh:
Agree here. Before going back together, I'd suggest hand cranking this thing over a few times, and see if you can get both valves to close fully.
No offense meant here, but you're sure you got the pushrods back in the right places? That'd definitely cause one valve to hang open. You'd also notice this while hand turning the engine, as it'll cause piston contact.
Last edit: 9 years 9 months ago by Tyler.
  • Ro-longo
  • Ro-longo's Avatar
9 years 9 months ago - 9 years 9 months ago #5051 by Ro-longo
Tyler wrote: No offense meant here, but you're sure you got the pushrods back in the right places? That'd definitely cause one valve to hang open. You'd also notice this while hand turning the engine, as it'll cause piston contact.
Now that you said that I would for sure double check that the push rods are in the correct spot. They have short and long ones. Don't remember which ones go where but if they get put in the wrong spot it can bend the valves.
EDIT: And on a side note, where did my other post go? I cant see it
Last edit: 9 years 9 months ago by Ro-longo.
9 years 9 months ago - 9 years 9 months ago #5054 by Tyler
Ro-longo wrote: Now that you said that I would for sure double check that the push rods are in the correct spot. They have short and long ones. Don't remember which ones go where but if they get put in the wrong spot it can bend the valves.
Sure can! Ask me how I know. :pinch:
Yeah, Dylan accidentally deleted it. :blush: We're talking to onyx to see if we can get it restored. Truly sorry about that!
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 9 months ago #5060 by Dylan
I'm sorry Ro-longo :blush: Have a new phone and still not really familiar with it. In stead of hitting the reply button I hit the delete....
Immediately sent a message to onyx. Should be able to put the post back.
  • Donnyten
9 years 9 months ago - 9 years 9 months ago #5066 by Donnyten
The valves are moving when hand cranking. I'm not too sure if the spring is supposed to close all the way? It was definitely closing though. When turning I can hear a noise which sounds like a spring is just snapping back to its default position . Should be normal or no?
video of the rear cylinder head while cranking
9 years 9 months ago #5076 by matt.white
That doesn't sound right. Others have made some great suggestions, as they're probably more accustomed to this exact engine.
One thought I'll add is I've seen bent valves make a similar noise. They don't move freely in the guide and pop back into place long after the cam lobe has passed.
One pretty quick check is either a leak down tester or even a home made air fitting tp put into the spark plug hole, and pressurise it and see if the offending valve is blowing out the intake/exhaust.
  • Donnyten
9 years 9 months ago - 9 years 9 months ago #5077 by Donnyten
For what its worth i redid the valve seals. Didnt notice any bent valves. When slowly turned over the snapping is non existent. Only when turning over quickly and with more force as shown in vid
Intake and exhaust rods are properly placed. Rocker arm bolts properly torqued.
  • billtest
  • billtest's Avatar
  • Work Monkey! Work! lol
9 years 9 months ago #5078 by billtest
Replied by billtest on topic Valve spring compression after torquing?
the post have been fixed.
-onyx
9 years 9 months ago #5083 by matt.white
You may have already said sorry, but does it all look normal or all a bit odd when the rockers are off?
  • Donnyten
9 years 9 months ago - 9 years 9 months ago #5084 by Donnyten
Looks pretty normal to me? Nothing looks out of ordinary. The other cylinder head does the exact same thing although i took the part the valve train off that one for demo purpose
9 years 9 months ago #5085 by matt.white
I hope my wording hasn't added confusion. What I meen does it all sit level until the rockers are put on?
  • Donnyten
9 years 9 months ago #5086 by Donnyten
Yes. All looks normal
  • Donnyten
9 years 9 months ago - 9 years 9 months ago #5109 by Donnyten
Back at it in the morning. Anyone else care to chime in? Just checked my torque specs which according to service manual says 11 foot pounds plus 30 degree angle. Pushrod and rocker arm replacement it states 22 foot pounds but I suppose this does not apply to me since the components are not being replaced.. otherwise I'll just torque to Specs put it all back together and see what happens when I run it. The sound seems to be coming from one of the cam lobes when it releases the lifter
Time to create page: 0.388 seconds
