Crank but no start
  • Dukeh
  • Dukeh's Avatar Topic Author
6 years 1 month ago #43535 by Dukeh
Crank but no start was created by Dukeh
99 jeep grand Cherokee 4.0. I have a crank no start no communication. I pulled and light tested fuses swapped relays. I replaced PCM with 2 different pcms both identical and flashed to vin. Im not getting 5v to my sensors. No fuel to fuel rail. Pump doesn't turn on. Im absolutely lost. It will try to turn over with starting fluid. I added pic of my dash to show all lights that are on. Any feedback on this nightmare would be greatly appreciated. Thank you in advance.
  • Dukeh
6 years 1 month ago #43536 by Dukeh
Replied by Dukeh on topic Crank but no start
Also gauges are not active. I do get very slight movement in my volt gauge. I pulled and cleaned all grounds i could find as well.
6 years 1 month ago #43539 by Chad
Replied by Chad on topic Crank but no start
Dukeh wrote: Im not getting 5v to my sensors. No fuel to fuel rail. Pump doesn't turn on.
Have you check POWERS and GROUNDS at the PCM connectors?
  • Dukeh
6 years 1 month ago #43541 by Dukeh
Not sure how to do that.
6 years 1 month ago - 6 years 1 month ago #43543 by Chad
Check for battery voltage at all the points circled in RED. Start with the fuses.
Make sure there is LESS than 100mv ( 0.1 volt) on the Ground wires circled in BLACK.
Do this with the key in the "RUN" position.
Do you know how to "back-probe"?
File Attachment:
File Name: 1999GrandC...gine.pdf
File Size:749 KB
Last edit: 6 years 1 month ago by Chad.
  • Dukeh
6 years 1 month ago #43546 by Dukeh
Much appreciated. I will check this out when i get home from work. I wasn't sure how to back probe but think i have figured it. Thank you for the help.
  • Dukeh
6 years 1 month ago #43550 by Dukeh
Chad wrote: Check for battery voltage at all the points circled in RED. Start with the fuses.
File Attachment:
File Size:749 KB
Just to be sure it this the cluster i will be back probing?
6 years 1 month ago #43551 by Chad
No. The PCM.
  • Dukeh
6 years 1 month ago #43557 by Dukeh
No. The PCM.
Ok. So i leave it plugged into the PCM pull the plastic cover off to expose wires and back probe them that way. I apologize im not the best with the electrical aspect of vehicles.
  • Dukeh
6 years 1 month ago #43561 by Dukeh
Ok.... my battery is dying i got a 9.76 reading off of it i need to recharge. On A2 back probe my reading was 9.68 on back probe of A22 my reading was .009. On back probe of A31 reading was .006. There was no fuse 22 15A in my relay box and fuse 11 20A was a reading of 9.68 it was my rear defroster. I added pics of fuse box and relay box for reference. Thanks again guys the help is greatly appreciated.
6 years 1 month ago #43562 by Tutti57
Replied by Tutti57 on topic Re:Crank but no start
You really want to make sure you have a good battery that's charged before doing any electrical testing. I hate to tell you to charge it and do it again, but you do. Low battery voltage causes all sorts of weird things to happen and you need a good baseline for your tests. 9v is very low. Even 12.0v is discharged.
Nissan Technician
The following user(s) said Thank You: Chad, Dukeh
6 years 1 month ago - 6 years 1 month ago #43563 by Chad
Dukeh wrote: There was no fuse 22 15A in my relay box and fuse 11 20A was a reading of 9.68 it was my rear defroster.
Hmm.:unsure:
It looks like we have some discrepancies. Do the wire colors for A2 and A22 match the diagram? (EDIT: Do all wire colors match the diagram?)
Can you post the Vin #?
  • Dukeh
6 years 1 month ago #43565 by Dukeh
Hmm.:unsure:
Ill be able to check wiring tomorrow and send pic. My vin# is 1J4GW58S6XC653886
  • Dukeh
6 years 1 month ago #43566 by Dukeh
Replied by Dukeh on topic Re:Crank but no start
Tutti57 wrote: You really want to make sure you have a good battery that's charged before doing any electrical testing. I hate to tell you to charge it and do it again, but you do. Low battery voltage causes all sorts of weird things to happen and you need a good baseline for your tests. 9v is very low. Even 12.0v is discharged.
Nissan Technician
Thank you. I will recharge it tomorrow. Battery was just bought in July so shouldn't have a problem taking a charge.
  • Dukeh
6 years 1 month ago #43576 by Dukeh
Dukeh wrote:
Hmm.:unsure:
pics of 32, 1 and 22 wires. Also pic to show the back of the cluster going into the pcm to verify it was the right one.
6 years 1 month ago - 6 years 1 month ago #43582 by Chad
The connector you have pictured is connector #3, or "C". We want connector #1, or "A".
The color sequence should match this:
As for the fuses, it looks like there are two different fuse boxes. Look around for another one.
The following user(s) said Thank You: Dukeh
  • Dukeh
6 years 1 month ago #43588 by Dukeh
Monde wrote: Have you checked the relay circuits? Pin 30 should have battery voltage VT/WT, Pin 85 battery voltage R/DB 86 Fuel pump control relay BR (Test light to ground and tip on pin 86, check for control with key on engine off or cranking. Test light should light.
Also, you may start unplugging sensors( no thermistors) to see if you can get the 5v reference back. Does your security light go out when you crank the vehicle?
I did test light my relays and the bulb did light up. Ill double check tonight when i get home. Yes security light stays on when cranking. Ill try pulling sensors again as well i tried that but may have did it wrong.
  • Dukeh
6 years 1 month ago #43590 by Dukeh
Chad wrote: The connector you have pictured is connector #3, or "C". We want connector #1, or "A".
Ok sorry about that i will check the right one out tonight and relay the information. There is a smaller fuse box underneath the dash ill see if thats the one as well.
  • Dukeh
6 years 1 month ago #43613 by Dukeh
So i back probed the correct cluster i believe. A2 12.53 a22 12.69 a31 .007 a32 .007. I recharged my battery it 12.7. I checked pin 85 fuel pump relay it was 12.54. Light test pin 86 no light.
  • Dukeh
6 years 1 month ago #43614 by Dukeh
Dukeh wrote: So i back probed the correct cluster i believe. A2 12.53 a22 12.69 a31 .007 a32 .007. I recharged my battery it 12.7. I checked pin 85 fuel pump relay it was 12.54. Light test pin 86 no light.
Time to create page: 0.366 seconds
