Long cranking
- Carstuff
- Thank you received: 19
V6 93 mazda sentia
- Ben
- Thank you received: 215
- Carstuff
- GeekDIYMechanic
If those checked out, I would then test spark and injection when hard starting occurs.
- Ben
- Doc n2mx
- Thank you received: 10
If you have a scope check your crank sensor, I think you will find that you have little or no sig for a few seconds then the sensor comes alive and starts..
Doc n2mx
- Carstuff
- Carstuff
- Carstuff
If the issue is due under fueling then pick a cold morning and spray a small ammount of brake or carb clean into the throttlebody before try to cold start the engine, if the engine starts almost instantly the problem is due to lack of cold start enrichment or other lean mixture issue . NB. don't use Eeezy Start or other ether based starting fluid for this as these can actually cause the engine to fire up without a spark
If the test makes starting even harder then it suggests the engine is getting too much fuel durring cranking so look at the evap solenoid or look for a leaky injector.
If the issue is spark related the cranking time will be unchanged, I would measure the voltage output from the crank sensor while cold cranking. You can use an multimeter with an AC voltage scale.
- Carstuff
- Carstuff
- Rockyroad
- Thank you received: 7
- Carstuff
- Carstuff
- Carstuff
There should be a by-pass that operates to supply power for initial prime.
- Expedition
