Using compression tester on exhaust?
  • ksat22
  • ksat22's Avatar Topic Author
4 years 3 months ago - 4 years 3 months ago #56948 by ksat22
Using compression tester on exhaust? was created by ksat22
Just wondering if an old-style compression tester (like the one pictured) screwed into an O2 bung would work to measure exhaust pressure. I guess the one concern I have is the scale on the gauge might go too high to get lower readings accurately enough.
Thoughts?
Last edit: 4 years 3 months ago by ksat22.
4 years 3 months ago #56949 by Noah
Replied by Noah on topic Using compression tester on exhaust?
Like you said, the pressure scale is inappropriate.
I use a Harbor Freight vacuum/pressure gauge. I have some fitting I scavenged to thread into an o2 bung, or I'll just drill a very small hole and hold the gauge there, and weld up the hole when I'm done. Had one yesterday, should have taken pix...
  • ksat22
4 years 3 months ago #56952 by ksat22
Replied by ksat22 on topic Using compression tester on exhaust?
Thanks for responding.
I have one of those gauges, too, but the flutter makes it hard to figure out what the actual reading is. I liked that the compression tester has a pressure holding valve (along with a spark plug fitting that fits in the O2 hole), which made consider using it. Perhaps adding a more appropriate psi-ed gauge to the tool would make it work,
4 years 3 months ago #56959 by juergen.scholl
Replied by juergen.scholl on topic Using compression tester on exhaust?
Though an appropriate scaled gauge will work I don't like messing with O2 for back pressure tests at all. Reason being they live in very confined spaces, often times very rusty -and breakable - and hot enough to burn you...
An easy alternative to a pressure gauge would be to connect your vacuum gauge to the intake and watch it's needle while rising the rpm gently from idle to medium range/light load and after a snap throttle. A MAP sensor reading/graph will give the same information.
