Verus - switch between OEM and OBD II
  • Flanner
  • Flanner's Avatar Topic Author
9 years 6 months ago #8793 by Flanner
Verus - switch between OEM and OBD II was created by Flanner
As mentioned in this video at the 4 minute mark:
To switch between OEM and OBD II without exiting the vehicle, see this video at the 35 minute mark:
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 6 months ago #8806 by Dylan
Replied by Dylan on topic Verus - switch between OEM and OBD II
Moved your post to diagnostic tool & techniques ;) Cool video. Haven't even seen it. Ivan and Eric together in one video :)
9 years 6 months ago - 9 years 6 months ago #8811 by Noah
Replied by Noah on topic Verus - switch between OEM and OBD II
There's a "Generic Functions" tab at the menu screen of each module.
For example, when you select PCM (or engine or however it's labeled) you'll get tabs for:
Codes Menu
Data Display
Functional Tests
Generic Functions
Troubleshooter
I don't think that you get the full list of generic OBD 2 functions, but I believe you can get at least freeze frame data, readiness monitors and maybe even Mode $06.
You might see different tabs and labels depending on what version you have and what you are working on.
Last edit: 9 years 6 months ago by Noah.
