Pressure Pulse Sensor
  • Joshasta
  • Joshasta's Avatar Topic Author
4 years 1 month ago - 4 years 1 month ago #58086 by Joshasta
Pressure Pulse Sensor was created by Joshasta
Hey guys,
Just trying to figure out why my Intake waveform looks a little different to what I am used to seeing online.
Each cylinder appears to have 2x downward pulses instead of just 1 like I am used to seeing.
Any ideas why? I have tried different time bases and voltage settings.
I am also wondering what your opinions are on this waveform.
I think my exhaust valves opening early and closing late on this cylinder. I have hydraulic lifters...
But mostly just wondering why my intake waveform looks the way it does, or what anyone can see from it.
I have labeled the intake pulls on the top.
Last edit: 4 years 1 month ago by Joshasta.
  • Joshasta
4 years 1 month ago #58094 by Joshasta
Replied by Joshasta on topic Pressure Pulse Sensor
This is Relative Compression and Intake while Cranking.
chA- Relative Compression AC Coupled
chB- Intake Pressure Pulse Sensor
chC- Ignition Control
I have the cylinders labeled. Relative Compression looks even. and Cylinder 7 has a deep intake pull.
Does anyone see anything else in here? Is there any problems in the way I have labeled my cylinders?
The following user(s) said Thank You: mashili
