Tailpipe Waveform
  • Joshasta
  • Joshasta's Avatar Topic Author
4 years 1 month ago - 4 years 1 month ago #58095 by Joshasta
Tailpipe Waveform was created by Joshasta
This is the best tailpipe waveform I have been able to get.
The engine is running, not cranking, like the test should be performed. When I crank only the waveform looks even worse.
I have the throttle closed. I have fuel disabled. I am not clear-flooding.
The waveform just doesnt look the way I have seen elsewhere online. Is there anything I can even see from this waveform? I dont think so...
I am using a Pressure Pulse Sensor.
Any ideas on capturing a better tailpipe waveform? How do you guys secure your pressure pulse sensor to the tailpipe?
Last edit: 4 years 1 month ago by Joshasta.
4 years 1 month ago #58103 by Matt T
Replied by Matt T on topic Tailpipe Waveform
I started out with a similar setup to yours and got horrible waveforms. This is what I ended up with. Allows the sensor to sit on the ground so it doesn't pick up vibration. And the smallish diameter tubing smooths the pressure pulses somewhat. 1/4" brake line and ~3/16" bore thinwall rubber tubing.
  • Joshasta
4 years 1 month ago - 4 years 1 month ago #58110 by Joshasta
Replied by Joshasta on topic Tailpipe Waveform
Ok, good stuff Matt T. Looks like you put that 1/4" brake line further into the exhaust then I did also. What sort of clamp is that your using to secure the brake line? Do you try and keep the brake line centered in the exhaust?
Heres another pic of mine from before. 2V scale. I can sort of see the characteristic "M" shapes the waveform is supposed to make, but there seems to be extra in the waveform still. I will try to implement some of your ideas.
Anybody have any comments on how I labeled the cylinders? I put #1 exhaust pulse just to the left of 360* And I am synced to #1 ignition trigger.
  • Joshasta
4 years 1 month ago #58149 by Joshasta
I tried duplicating the tailpipe adaptor and I got these. Much better!!
I see some differences in valve overlap.
Let me know what you see!
4 years 1 month ago #58152 by Noah
Replied by Noah on topic Tailpipe Waveform
Quite an improvement!
4 years 1 month ago #58157 by juergen.scholl
Replied by juergen.scholl on topic Tailpipe Waveform
The waveform improved and now it is useable for diagnostics, well done.
You may want trying to put on the degree rulers within the pico software , using 8 of them will relate each cylinder to specific events. I like this for easy viewing and measurements compared to the overlay you applied.
4 years 1 month ago #58165 by Chad
Replied by Chad on topic Tailpipe Waveform
I use a mic stand.
4 years 1 month ago #58177 by Noah
Well that's crafty :)
