2013 ACURA TSX 2.4L L4
  • ThunderBull009
  • ThunderBull009's Avatar Topic Author
3 years 11 months ago #58807 by ThunderBull009
2013 ACURA TSX 2.4L L4 was created by ThunderBull009
2013 ACURA TSX 2.4L L4,
1 Antilock Braking System Code,
61-01 Power Source Failure for ECU (Low Voltage)
3 years 11 months ago #58809 by Ben
Replied by Ben on topic Re:2013 ACURA TSX 2.4L L4
This is for low voltage, if battery or charging system is bad it will set if both of those are good than we can get you wiring diagrams for voltage and ground supply circuit . If this is a history code it may have set at a time when the battery was low.
