Autel maxisys ultra and snap amp clamp
  • bizz2222
  • bizz2222's Avatar Topic Author
3 years 9 months ago #59988 by bizz2222
Autel maxisys ultra and snap amp clamp was created by bizz2222
Can I use my snap on amp clamp on a autel maxisys ultra I wanna use it to find a parasitic draw
3 years 9 months ago #59989 by Tyler
Replied by Tyler on topic Autel maxisys ultra and snap amp clamp
Which amp clamp do you have, specifically?
Yes, you can use just about any amp clamp with the Ultra. But, if the Snap-On clamp has banana jacks, then you'll need an adapter to connect it to the BNC ports on the Autel VCMI:
www.aeswave.com/AES-Flexible-Adapter-Ban...-BNC-Male-p8956.html
You'll also have to note the signal conversion on the Snap-On probe and set the scale on the Ultra accordingly. For example, the Snap-On EETA308A uses this ratio:
3 years 9 months ago #59997 by Noah
Replied by Noah on topic Autel maxisys ultra and snap amp clamp
You may not be successful using the clamp to find a draw if it is in the order of tens or hundreds of milliamps.
  • bizz2222
3 years 9 months ago #60000 by bizz2222
Replied by bizz2222 on topic Autel maxisys ultra and snap amp clamp
I have this same amp clam
  • bizz2222
3 years 9 months ago #60001 by bizz2222
Thank you here is a picture of a plug that came with the maxisys ultra this should work right ? And I have to use a Chanel on the j box not the multimeter Jack's right
3 years 9 months ago #60005 by juergen.scholl
Replied by juergen.scholl on topic Autel maxisys ultra and snap amp clamp
The adapter cable will allow to connect your amp clamp to your scope.
You would plug into one channel of your scope module (this shouldn't be a j-box).
Keep in mind that the amp clamp will drift over time and the readings may not be accurate when recording longer periods and the battery may run low as well.. There are workarounds though.
You may consider a different method if you wanted to check for a draw for hours/overnight.
The following user(s) said Thank You: bizz2222
