Voltcraft MS-410 Magnetic Field Detector Pen
photos.google.com/share/AF1QipM4YYeEPzXZ...RGhUeFdsUXVKWHJjLTFR
The cars I work on aren't prone to coil primary ignition faults but I see a lot scondary high tension faults. About 16 years back MG-Rover changed over from a distributor system to a wasted spark sharing a plug top coil, initially we were seeing a lot of coil failures around 30,000 miles and the misfire codes didn't always point to the correct coil, as a result we were adopting a shotgun approach to coil failures and almost treating coils as a 30,000 mile service item.
I ended up with a pile of coils under the bench so rigged up a coil tester to sort good from bad. After stress testing half a dozen coils I realised the problem was the spark was tracking along the rubber boot to the metal body of the spark plug. After that I reverted to using a 10% narrower spark plug gap that been specified for the same engine type before the change to plug top coils. No change in performance or emissions but we had less problems with the coils.
Thats pretty interesting, I never would have thought of that.
