Appropriate amp clamp for ignition system troubleshooting
- josegumby
9 years 3 months ago #10897
by josegumby
Appropriate amp clamp for ignition system troubleshooting was created by josegumby
Hi,
I have a (hopefully) simple question. I have a Honda Element that feels like it has a little bit of a misfire under moderate load ("shudder" under moderate acceleration). I would like to use an amp clamp on the fuse circuit ( Fuse Buddy Mini Current Loop ) for the ignition system to see if I can narrow down the problem to a specific ignition coil (to avoid blindly replacing coils, of course). I already have a 4-channel picoscope, and I am looking at the following two amp clamps:
PICO TA018 amp clamp ($159.00)
PICO TA189 amp clamp ($459.00)
Will the (far cheaper) TA018 60-amp amp clamp work for me to be able to clearly see the ignition system waveforms, or am I going to need the far more expensive one?
I need to revisit the scanner-danner premium youtube pages to refresh myself, but I think having an amp clamp in my arsenal would really be nice. I just want to make sure I have the right one for what I need to accomplish at the moment.
Thanks,
Curt
Thanks,
Curt
9 years 3 months ago - 9 years 3 months ago #10899
Replied by Andy.MacFadyen on topic Appropriate amp clamp for ignition system troubleshooting
The peak current on a coil is normally no more than 10 amps so the low range clamp is all that is required, however you don't need to go for an official Pico all you need is a generic one and BNC to Bannana adaptors and you can save money or see the tools section on this forum.
Link to Amp Clamp in Tools Secion of the Scannerdanner Forum
If you want a BNC connector clamp Hantek do a budget one, just make sure you buy from a seller with a good returns policy in case it arrives DOA.
Last edit: 9 years 3 months ago by Andy.MacFadyen.
The following user(s) said Thank You: josegumby
- josegumby
9 years 3 months ago #10900
by josegumby
Replied by josegumby on topic Appropriate amp clamp for ignition system troubleshooting
Great! Thank you!
- Dylan
- Belgium, Europe
- Thank you received: 327
9 years 3 months ago #10915
by Dylan
Replied by Dylan on topic Appropriate amp clamp for ignition system troubleshooting
I have the PICO TA018 amp clamp ($159.00) and it works great. You don't need that expensive precision clamp.
Time to create page: 0.457 seconds
