Does the relearn function free on verus edge?
- Hamad
2 years 1 month ago #66799
by Hamad
Does the relearn function free on verus edge? was created by Hamad
Hello,
i've bought a used snap on verus edge becuse of SD vedios on Youtube. Its sw no is 23.2
The tool is ok but if i need to do a relearn funtion the tool asks for wifi connection and i couldnt connect its sayed Restricted
any help?
any help?
2 years 1 month ago #66810
Replied by Noah on topic Does the relearn function free on verus edge?
If you are talking about the "service resets" tab, then you will require a current subscription and Internet connection. Most often, any of the commands available in that menu can be found elsewhere while navigating the tool, they just lump them all together conveniently under one tab, probably as another justification for you to keep software up to date. So you're really not missing any of the functions of the tool, you will just need to push more buttons to use them.
I have run a Verus Edge every day for years and will be happy to answer questions you have about it.
- Hamad
2 years 1 month ago #66842
by Hamad
Replied by Hamad on topic Does the relearn function free on verus edge?
Thank you so much for your informitive reply
unfortunately i usually find only Function Test not Special Function
