When is it not safe to use a test light?
- Ora1996
- Thank you received: 2
1 year 11 months ago #67934
by Ora1996
When is it not safe to use a test light? was created by Ora1996
Hey guys so my question is I’m slowly learning testing of electrical when is it not safe to use a stab light/ test light so you don’t toast a module? And I know you can’t explain every scenario just a little confused on this topic. Thanks.
1 year 11 months ago - 1 year 11 months ago #67969
Replied by Tyler on topic When is it not safe to use a test light?
Most of the danger comes from not understanding the circuit being tested, IMO. For example, you're testing an incandescent tail light circuit that normally draws 500 mA, and you're using your 150 mA test light. There's no danger there - you're not making the circuit carry any more current than it does normally. If you were testing an LED tail light circuit that draws 50 mA with your 150 mA test light, there may be danger there.
That's why it's important to understand the circuit being tested, and know the draw of your test light. That's also why LED test lights get branded as 'computer safe' - They barely draw any current, and therefore can't hurt anything.
If you have a Premium subscription, there's an excellent video covering this:
www.scannerdanner.com/scannerdanner-prem...xpanded-content.html
For whatever it's worth, I generally consider an incandescent test light to be pretty safe. I can't recall ever damaging a module with one, or worked with anyone who has.
Last edit: 1 year 11 months ago by Tyler.
- Ora1996
1 year 11 months ago #67972
by Ora1996
Replied by Ora1996 on topic When is it not safe to use a test light?
Ok thanks for the reply. I’ll definitely watch the video.
I’m slowly trying to watch all of the videos.
- MiaAnderson
1 year 10 months ago - 1 year 10 months ago #74854
by MiaAnderson
Replied by MiaAnderson on topic When is it not safe to use a test light?
Thank you for the information.
Last edit: 1 year 10 months ago by MiaAnderson.
