SO Vantage Ultra Pressure Transducer
  • Rottiguy76
  • Rottiguy76's Avatar Topic Author
9 years 2 months ago #11829 by Rottiguy76
SO Vantage Ultra Pressure Transducer was created by Rottiguy76
I have a Snap On Vantage Ultra and would like to add a pressure transducer to it. Snap On tells me they do not offer one for the Vantage Ultra. Has anyone had any success in adding one to their Vantage Ultra? I see one on the SO website that says it will work with Vantage but its a lot of money and do not want to order it if it wont work. Thanks for your help!
9 years 2 months ago #11830 by matt.white
Replied by matt.white on topic Re:SO Vantage Ultra Pressure Transducer
We don't get the ultra here but surely the maths would be pretty simple, similar to an amp clamp. Instead of 1 mv/1 amp it would be 1mv/ 1psi or similar. At the end of the day a scope is just a volt meter that can draw pictures instead of just numbers. You got a link to the pressure transducer you're looking at?
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
9 years 2 months ago #11831 by Ro-longo
Replied by Ro-longo on topic Re:SO Vantage Ultra Pressure Transducer
To use the snap-on pressure transducer you will need to use this adapter www1.snapon.com/diagnostics/us/Diagnosti.../PressureAdapter.htm
the Vantage Ultra has the same scope as the Modus Ultra and Modus Edge, so any accessory for the Modus will work for the Vantage Ultra. Or you could make your own pressure transducer.
9 years 2 months ago #11836 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Re:SO Vantage Ultra Pressure Transducer
I haven't used the Snap-on but the maths with pressure transducers generally tends not to be quite as simple as current clamps. 0.5v is generally atmospheric pressure and 4.5v is the maximum pressure reading of the sensor.
9 years 2 months ago #11845 by matt.white
Andy.MacFadyen wrote: I haven't used the Snap-on but the maths with pressure transducers generally tends not to be quite as simple as current clamps. 0.5v is generally atmospheric pressure and 4.5v is the maximum pressure reading of the sensor.
Well there you go. I stand corrected.
9 years 2 months ago #11848 by Tyler
Replied by Tyler on topic Re:SO Vantage Ultra Pressure Transducer
I've been using the Fluke PV-350 with my Modis Ultra for a few years, no issues. It's just like matt.white described, 1mV = 1 PSI or 1 kpa depending on the scale. Use a normal voltage trace and you're good to go. :cheer:
