Old MODIS Scanner-- what's the hook up procedure for coil testing?
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
9 years 2 months ago #11858 by Mechanic 350
I have an old modis scanner. i saw paul using the uscope to test secondary ignition. i wanted to know if i can do it with my modis?
and, what's the hook up procedure and plugs needed for the test. any help would be appreciated. thanks guys.
9 years 2 months ago - 9 years 2 months ago #11859 by Tyler
Yep, your old Modis can do that easily! You'll just need some kind of secondary ignition adapter. There's several good options, depending on how much you want to spend. Something like the AESwave Universal Secondary Test Lead set will work well on many different ignition designs. I used that kit for several years before getting a Pico TA204 .
Both will hook up to your Modis with banana jacks, and both can be used on a standard voltage trace with a trigger. The signal generated by the probes is anywhere from 0-10V depending on the ignition design, so you'll have to fine tune your scope setup every time you hook up to get the best picture. ;-) I usually start with a 10ms screen and a 5V scale.
Snap-On also produced a HUGE range of ignition adapters for the Modis and Vantage. Coil-in-cap, specialized COP adapters, secondary flags, all kinds of stuff. Have a look at the Snap-On site to get an idea of what's out there.
Last edit: 9 years 2 months ago by Tyler.
The following user(s) said Thank You: Mechanic 350
9 years 2 months ago #11883 by altautomotive
Primary reflects secondary so an alternative would be view primary with the current ramp overlaid.
  • Mechanic 350
9 years 2 months ago #11929 by Mechanic 350
Thank you so much for your help I really appreciate it
