Question on Pressure Transducers
- waxerk5
My question is, wouldn't it be more economical to just buy the 500psi unit and if so, will I be ok testing for smaller pressures in the realm of the 100psi transducer without having to buy a 2nd transducer? Basically, will a 500psi unit read lower pressures that the 100psi transducer is designed for? Trying to buy once, cry once here...
Thanks
Steven
- FastEddieOBD
- Thank you received: 2
- waxerk5
I wanted to buy the larger transducer so I could do more with it.. But will a low pressure item still show up as accurately on a 500psi transducer like it would on a 100psi unit?
- FastEddieOBD
- waxerk5
- FastEddieOBD
- waxerk5
Andy.MacFadyen wrote: I have seen a handful posts around the net complaining of signal noise with Fluke transducer.
Hi Andy, do you recommend a different transducer that's compatible with Modis/Vantage Pro scopes?
- waxerk5
FastEddieOBD wrote: I am not familiar with the 100psi version. However the 500psi version I own has the transducer hardwired to the internal circuit board of the unit. If the potential one you are looking to acquire is setup like that, it just would not be practical to switch from one to the other
Good to know.. that tells me that they are 2 different models all together. I definitely do NOT want to buy 2 of those things like that. Thanks for your responses.
If you're looking at doing crankcase/intake/exhaust pressure pulse testing, however, you'll need another tool IMO. The PV350 is not sensitive enough to do that kind of thing.
Not trying to tell you how to spend your money, BUT if I could go back in time, I'd just get a Pico WPS500.
- Paul Marchant
- Thank you received: 12
www.scannerdanner.com/forum/diagnostic-t...ransducer.html#11460
I've progressed a bit more on this project, and have an inexpensive (ebay) 100psi transducer working with it.
I've just bought a 5000psi transducer (50 euros) and plan to make up the adaptors to monitor brake fluid pressures and ABS modulator pressure waveforms. This is a longer-term project but is underway.
