Verus scope has one Ground port
- karim
- Thank you received: 2
9 years 2 months ago #12079
by karim
Verus scope has one Ground port was created by karim
Dears,
I want to check Fuel injector current and voltage using snap on verus scanner. If I connect the probe to the ground, how can I use channel 2 scope for voltage of the injector? the ground is occupied by the Low Amp Probe.
Is it possibe to share the ground port for all the channels?
Thanks for your quick response and helps
- matt.white
- Thank you received: 29
9 years 2 months ago #12081
by matt.white
Replied by matt.white on topic Verus scope has one Ground port
The original SO leads have a piggy back for the earth so you can stack them. I take it you don't have any original leads? With a few alligator clips you may be able to link them together. Or some banana plug adapters if you have any.
- karim
9 years 2 months ago #12082
by karim
Replied by karim on topic Verus scope has one Ground port
Thank you very much matt.white
You are right. I dont have OEM leads for my verus. I use alligator clip to share the ground for the other channesl.
Thank you again
Have a great weekend
Thank you again
- Dylan
- Belgium, Europe
- Thank you received: 327
9 years 2 months ago #12083
by Dylan
Replied by Dylan on topic Verus scope has one Ground port
Moved your topic to the 'Diagnostic tools and techniques' section Karim.
The following user(s) said Thank You: karim
9 years 2 months ago #12122
Replied by Noah on topic Verus scope has one Ground port
You can get a set of leads from AES wave if you're interested.
Check out the "Tools" tab at the top of the page
