bi-directional control tool
  • robert.lesaca
  • robert.lesaca's Avatar Topic Author
9 years 1 month ago #13563 by robert.lesaca
bi-directional control tool was created by robert.lesaca
Hello All...My scanner does not have a bi-directional capabilities but I got hold of a tool that does it. Its called PWM Bi-Directional Controller by ADPT (Automotive Diagnostic and Publishing). Some of you might or might not heard of it but has a bunch of diagnostic tool that you can employ. Just Google : autodiagnosticandpublishing.com
...for what its worth...
Robert
9 years 1 month ago #13575 by Noah
Replied by Noah on topic bi-directional control tool
Be sure to let us know how it works out for you.
  • robert.lesaca
9 years 1 month ago #13596 by robert.lesaca
Replied by robert.lesaca on topic bi-directional control tool
sure will...
  • robert.lesaca
9 years 4 weeks ago #13602 by robert.lesaca
Hi Noah...i used the PWM bi-drectional controller on a purge solenoid and it works as expected. the only thing is you have to disconnect the solenoid in order to check its integrity. you can even connect it to your scope and adjust the pulse width in order to see how the solenoid behaves. and of course you check your wiring integrity the usual way...
9 years 4 weeks ago #13603 by Noah
Cool!
Can you set it to run for an exact predetermined period of time, for say an injector balance test?
9 years 4 weeks ago #13605 by bruce.oliver
Replied by bruce.oliver on topic bi-directional control tool
aeswave has one too and it's cheaper. Completely adjustable and shows amp draw.
Power Pro tester
  • robert.lesaca
9 years 3 weeks ago #13706 by robert.lesaca
unfortunately it is not recommended for injectors, coil and throttle body use....
