Tools
  • Lingle
  • Lingle's Avatar Topic Author
9 years 2 weeks ago #13954 by Lingle
Tools was created by Lingle
Can the lab scopes use a 0 - 300 psi 4 -20mA transducer for compression testing.
9 years 2 weeks ago #13958 by Tyler
Replied by Tyler on topic Tools
Can you link us to the pressure transducer you had in mind? The current output is good, but I'm mostly wondering about it's voltage output. Most I've seen work on a 5V scale.
  • Lingle
9 years 2 weeks ago #13960 by Lingle
Replied by Lingle on topic Tools
I work with 12 and 24 volt systems that power the transduce...Mostly diesel application. "Link", something, I do not know. @ 61, I did not embrace the computer age very willingly.....:)
9 years 2 weeks ago #13961 by bruce.oliver
Replied by bruce.oliver on topic Tools
Scopes don't measure amps, they measure voltage. Snapon scope present for pressure transducers is 0.5v for 0 psi and 4.5v for 300 psi or 500 psi depending on which one you use. Or you can just setup your voltage scale for whatever your sensor and pressure range is.
What scope do you have?
  • Lingle
9 years 2 weeks ago #13963 by Lingle
Playing with a Hantek 1008C before spending serious money.
9 years 2 weeks ago #13968 by bruce.oliver
Lingle wrote: Playing with a Hantek 1008C before spending serious money.
Ok, so no presents. Then you need to know what the input voltage is for that pressure sensor and what the operating range is. Most that I've seen is 5v input and 0-5v output or .5-4.5 output
9 years 2 weeks ago #13972 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Tools
300 psi won't be up to doing Diesel engine compression testing, you need a 500psi (35 Bar) sensor.
The normal low cost 3 wire industrial sensor you find on eBay use a 5v supply and atmospheric pressure = 0.5v the maximum rated pressure = 4.5v
