mobile gas detector for quick headgasket diagnosis
- Olmer
- Thank you received: 8
9 years 2 weeks ago #13976
by Olmer
For God so loved the world, that he gave his only begotten Son, that whosoever believes in him should not perish, but have everlasting life. John 3:16
Im blessed to serve a mighty God who forgives me with nothing but the grace He has given me by His son Jesus Christ
mobile gas detector for quick headgasket diagnosis was created by Olmer
anyone know of a good mobile gas detector, I mainly want it for testing head gasket failures I buy cars to fix up and sell and want a very fast and reliable way to test for gases in the coolant bottle or radiator. I dont really trust the chemical test kits for early head gasket failures or maybe even bad ones sometimes lol,
If anyone has one they use and believe its reliable what is the name and price of it??? thanks
9 years 2 weeks ago #13982
Replied by Noah on topic mobile gas detector for quick headgasket diagnosis
This is something that's been discussed before, but I don't think anyone ever came up with a viable solution.
If you Google hydrocarbon detectors, there is a bunch of options. From the super cheap to extra expensive. I just haven't had the money to gamble with to try any of them out.
9 years 2 weeks ago #13984
Replied by Andy.MacFadyen on topic mobile gas detector for quick headgasket diagnosis
I have found there is no single test that will show all cylinder head gasket failures. Not all head gasket failures leak combustion gas into the coolant, the chemical test is as valid as any other. Usually if combustion gases are leaking into the coolant youcan detect a stale smell in the coolant tank .
Another test you can do is pull the spark plugs if coolant is leaking into the combustion chamber you will often find the spark plug on one cylinder looks bleached or dyed from the coolant, also the top of piston will be relatively clean of carbon.
- Olmer
9 years 2 weeks ago #13985
by Olmer
Replied by Olmer on topic mobile gas detector for quick headgasket diagnosis
thanks, I will do a google research, I was just hoping to be able to find someone out there that has found a good one and has had good success with it so like you I wouldnt have to gamble with my own money and be the guinea pig lol,
- Olmer
9 years 2 weeks ago #13986
by Olmer
also as far as having a headgasket failure that does not leak combustion gases into the coolant you will not have a overheat problem right? just other symptons correct?
- Olmer
9 years 2 weeks ago #13987
by Olmer
9 years 2 weeks ago #13990
You can have one way leaks coolant going into the cylinder. You can also can have oil and coolant and oil mixing without going through the cylinder, external leaks and manifold leaks.
Olmer wrote: also as far as having a headgasket failure that does not leak combustion gases into the coolant you will not have a overheat problem right? just other symptons correct?
