Knock Sensor Benefits in Diagnosis
  • naros812000
  • naros812000's Avatar Topic Author
9 years 2 weeks ago #14029 by naros812000
Knock Sensor Benefits in Diagnosis was created by naros812000
Dears,
I would like to know how to benefit Knock Sensor in my Diagnosis. Is there a way that I can benefit it? Any video on Knock sensor value change and what does high and low value indicate? what is normal range in diagnosis?
Any documents and any video can help?
Thank you.
9 years 2 weeks ago #14040 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Knock Sensor Benefits in Diagnosis
I will move this into Diagnostic Tools and Techniques section.
To answer your question the short answer is a knock sensor won't tell you much.
A knock sensor is simply a piezo crystal micorophone that is tuned only to react to a quite narrow range of sound vibration frequencies usually between 8,000 and 17,000 hz.
The frequency is tuned to the sound of pre-ignition pinking or pinging in north America. The frequency of the pinking/pinging is different for each engine and largely depends on cylinder bore - big bore engines lower frequency, small bore engines higher frequency.
The following user(s) said Thank You: naros812000
Time to create page: 0.265 seconds
