Chemicals/solvents
- Ben
- Thank you received: 215
8 years 11 months ago #14814
by Ben
Chemicals/solvents was created by Ben
What are you guys using for penetrates ,cleaners ,degreaser , I'm particularly interested in corrosion cleaners let's say lightbulb socket anything that works?
- Ben
8 years 11 months ago #14815
by Ben
Replied by Ben on topic Re:Chemicals/solvents
I use castle shop solve for my everything cleaner and Schafers citrus degreaser for degreaser and I'm up in the air on castle thrust and Schafers p90
8 years 11 months ago - 8 years 11 months ago #14816
Replied by Andy.MacFadyen on topic Chemicals/solvents
I used to clean bulb sockets, plugs and contacts with a product called "Corrosion Gone" now I use Vinegar or a dilute Citric Acid solution After acid treatment acid residue must be washed off with a very dilute solution of baking soda, A Citric flush wil also clear blocked radiators and heater matrix.
For cleaning very delicated Hot Film MAF's I have discovered Foaming Circuit Board Cleaner which s fairly cheap and very effective.
For rusted threaded parts Acetone mixed with a little engine oil or "Duck Oil" (similar to WD40) makes a great penetrating fluid.
For anti-seize compound I uses one that contains stainless steel rather than copper it isn't cheap but is very effective especially on alloy wheels it however much messier to use than the copper based products.
For taking oily finger marks off car paint work and steering wheels I use am aerosol of furniture polish.
The following user(s) said Thank You: Ben
8 years 11 months ago #14954
Replied by Noah on topic Chemicals/solvents
I use KA-88 purple degreaser,
P B'Laster penetrating oil or 3 in 1 household oil,
And QD electrical contact cleaner.
- Ben
8 years 11 months ago #14962
by Ben
Another thought any good sensor safe alternatives for the evap smoke machine?
