PC based scan tool under $600
- Ibrahm
I am begginer in vehicle technician field. Following Paul Dannet (scanner danner) for last 2 years.
But can't afford expensive tools like snap-on devices.
Can any one suggest me cheap PC based tools under $600?
That can operate most of the modules in most brands .
My personal research pointed me to autoboss PC-max .
Is their any thing else working better and more then this under my budget?
Thanks in advance
- wes p
- Thank you received: 3
- Ibrahm
- arbez
- Thank you received: 53
For $600.00 you should be able to pick up a used Autel scanner (DS708 or for a little more a mini) or even a Snap-On Solus. Unless you work on the newest of cars, the older software shouldn't be much of an issue. All are a good place to start. Unfortunately, one scanner isn't going to do everything. Whatever you choose, educate yourself on the cost of the updates. Snap-On wants a grand to update my Solus Edge & the Autel was $600 or $700 last time I did it. Figure that into your long term plans.
If your stuck on a PC based tool, the autoenginuity is as good a place to start as any. The base tool is about $250, but if you want any "enhanced" abilities, your looking at $1200 for Asian & Domestic. Euro is more. I do remember that the updates were very reasonable & the tech support was very good also. I stopped upgrading mine when the hardware had to be replaced (at my expense) to handle the newer software.
There are a lot of options out there. Check Craigslist & Ebay. Good deals to be had, if your patient. Buy something cheap, to get started. You can always sell it later, after you upgrade & probably recoup most of your investment.
Good luck - arbez
I just get more fixes, more quickly with the snap on scanners.
There's a lot of info built right into the tool that you would have to go digging for otherwise.
I spent an hour playing with the top tier Mac Tools EDT10 made by Bosch trying to get to the bottom of a VSA light on an Acura TL.
After getting no where, I plugged in the Solus and the car was fixed in less than 20 minutes.
- Ibrahm
On The Way Exploring PC based tools, i found VDM scanner
is it better to work with it?
- arbez
Plenty of $50.00 code readers out there that will read/clear codes & give you some live data. If you need more than your going to spend more. Look hard at the Autel DS808 ( www.amazon.com/Autel-Diagnostic-Function...=Maxidas+DS808&psc=1 ). $750.00 with the coupon. New with updates. Proven platform. Really good for the money & when you outgrow it, you can sell it & recoup most of your money.
Save your Xmas money, beg & borrow. Do what you have to do to buy something that will allow you to make money. Buying something that is just a glorified code reader isn't going to do you any good in the long run.
Talk to people & find what they use. It's the best way to get something that will really be useful.
GG - arbez
- Dtnel
- Thank you received: 67
IF you're working in a shop and don't have to bad a credit you can get a really good used Solus Edge albeit for about 4 times the amount you mentioned but if you have it and work hard enough doing side stuff you can make the payments. IF that's not your case start small and work your way up.
I traded my Solus Edge in for just as much as I paid for it at 7 months. It was current on updates. Moved into a Modis Edge for the Oscilloscope function. Snap On had a big promotion going where they were begging dealers to give top dollar for trade ins to get newer stuff such as the modis edge, Zeus into people's hands.
Had I known Snap On was coming out with the Zeus I would've waited. I just do side diagnostic work within the scope of what I know I can handle. Hopefully someday I can jump to it and leave all the other worries behind and gain a bunch of new worries.....
I know my Snap On guy will give me what I paid for the Modis Edge but I'm not sure if I want another payment after just paying $5k off in 6 months. I think my guy quoted me my Modis plus 4k , no interest through him. I generally pay about $500 a month. If you can do $400-$600 a month in side work after hours and on weekends you can move into something nice sooner than you think.
I had a innova 3160 and still do somewhere around here that'll show live data such as O2 , Fuel Trims and I paid less than $200 on Amazon. It does ABS and Air Bags which was the reason I bought it. Some of the air bag codes won't show on that device though as I found out the hard way.
- Dtnel
- Ibrahm
www.ucandas.com/
- arbez
Never heard of that tool. Website looks old. Advertising Windows 8. Doesn't appear to be available in the US.
Stay away from obscure tools. There is a reason they are cheap & no one has heard of them. They are no good with no support.
Your coming here for professional opinions. If you wan't something that works & has good support you need to look at Autel, Snap On, Launch. Probably others, but you severely limit yourself with the $600.00 dollar budget.
You haven't explained why you are stuck on a PC based system. You are going to spend at least a grand on a usable setup that has enhanced features & it will be much less convenient than a hand held unit. Like I said earlier, I have an old AutoEnginuity, with enhanced domestic, Asian & European, that I haven't used in years. It is an OK system, but dragging a PC around on every test drive is a PITA. A total waste if time and time is money.
For $600.00 you are going probably going to get a glorified code reader that displays generic live data. Nothing enhanced. If you are going to do this for a living, you need to stick with the name brand tools. Everybody uses them for a reason.
Look for a used Autel DS708, its a good tool to start with & can make you money. For a little more than your $600.00 You can pick up an Autel DS808 (highly recommended) or a used Snap On Solus. Thousands of us are using these tools every day. There is a reason for that.
You came here for advise. Now take some....... brother
Don't call me dude - arbez
- arbez
www.scannerdanner.com/forum/diagnostic-t...er.html?limitstart=0
- Dtnel
As you stated I would've either got the upgrade you recommended or waited a month or two until I could. Anyways he seems happy and that appears to be what counts.
- ScannerDanner
- Administrator
- Thank you received: 500
arbez wrote: I'm not your brother.
arbez, I appreciate your help and comments to Ibrahim, most of it was extremely thoughtful and was something that would help him make a decision. Except for the above comments. It was completely unnecessary and rude. Sorry man, I'm not down with this kind of stuff here. Ibrahim said nothing to you to deserve to be spoken to this way. I understand that sometimes text on a screen does not show intent. Maybe you can clarify. Maybe not. In any case, all I ask is that we all respect each other here.
Don't be a parts changer!
- arbez
Sorry, I meant it to be funny. I didn't mean to offend anyone. It wont happen again.
arbez
- ScannerDanner
- Administrator
arbez wrote: Paul,
arbez
arbez, thanks man. This is where it is tough sometimes to gauge intent with just text on a screen.
- arbez
- dkggpeters
- Thank you received: 13
- arbez
dkggpeters wrote: I have heard statements that Autel will not be providing updates for the DS808 anymore as the last update is Dec 2017. Is this true? I would hate to buy a scanner that is not being supported anymore
Who told you that? It's a new tool, why wouldn't there be updates? I would expect it to receive the updates like all their other scanners. Show us something from Autel that indicates there are no updates.
I would call their support:
Support Phone
1-855-AUTEL-US (288-3587)
0086-755-22672493 (Other)
Let is know
