injector timer tool
  • scopeman
  • scopeman's Avatar Topic Author
10 years 2 months ago - 10 years 2 months ago #1584 by scopeman
injector timer tool was created by scopeman
No eBay APP ID and/or Cert ID defined in Kunena configurationHi has anyone used one of these timer tool for checking injectors? wondering if they are any good and are there any limitations using this type.
for some reason not showing link.
Last edit: 10 years 2 months ago by scopeman.
  • Doc
  • Doc's Avatar
  • Sharing the little I know
10 years 2 months ago #1585 by Doc
Replied by Doc on topic injector timer tool
I have a VS211 Sealey tool from McCormick tools, it works well enough for a budget tool.
Cheers
Youtuber specialising in Diagnostic techniques, sharing skills and helping technicians be the best they can be #Picoflu
10 years 2 months ago - 10 years 2 months ago #1589 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic injector timer tool
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/i81rb962hx44/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 304 in /home/i81rb962hx44/public_html/components/com_kunena/template/aurelia/layouts/message/item/default.php on line 86
Layout was rendered in /home/i81rb962hx44/public_html/components/com_kunena/template/aurelia/layouts/topic/item/message/default.php on line 34
  • scopeman
10 years 2 months ago #1608 by scopeman
Replied by scopeman on topic injector timer tool
Thanks Andy,not sure why i could not get link to work but yes that is the one .Will be getting one of these soon just to add to tool kit .Where did you get the connectors from? or did you make your own.In the online instructions it says it can be connected with either lead to the injector,is this right ?
Cheers
10 years 2 months ago - 10 years 2 months ago #1612 by Andy.MacFadyen
Injectors usually work fine connected with the polarity reversed but I try to make sure I keep the + & - the original way round.
Just used a few standard injector connectors salvage from junkers.
Last edit: 10 years 2 months ago by Andy.MacFadyen.
10 years 2 months ago #1689 by Noah
Replied by Noah on topic injector timer tool
That's the same one I use. Good cheap tool. I also have some pig tails I made from junk harness connectors to make it easier to use.
The following user(s) said Thank You: scopeman
  • scopeman
10 years 1 month ago #1719 by scopeman
Cheers everyone will be adding one soon.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
10 years 1 month ago #1734 by ScannerDanner
Replied by ScannerDanner on topic injector timer tool
Don't be a parts changer!
