Test light on PCM
  • Tutti57
8 years 9 months ago #16913 by Tutti57
Test light on PCM was created by Tutti57
I've read some people saying that using the test light on a module is a bad idea. Is this a theoretical bad idea or have people actually had issues doing it?
8 years 9 months ago #16915 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Test light on PCM
O2 sensor heaters, Injectors, coils, stepper motors and relay coil all carry a current which is higher or similar to the current through an ordinary tungsten test light so they won't damage the drivers in the ECU. What you have to be careful about shorting a computer switched output to ground or directly to heavy load such as a fuel pump or fan motor.
The 5v ref on fuel level sensors , 2 and 1 wire temperature sensors generally pass through a resistance before they leave the computer so will survive a test light or even a short to ground.
The 5v reference to 3 wire sensors such as TPS, MAP and other Pressure sensors is pretty well protected and can survive being pulled down to ground
  • Tutti57
8 years 9 months ago #16953 by Tutti57
Replied by Tutti57 on topic Re:RE: Test light on PCM
Andy.MacFadyen wrote: O2 sensor heaters, Injectors, coils, stepper motors and relay coil all carry a current which is higher or similar to the current through an ordinary tungsten test light so they won't damage the drivers in the ECU. What you have to be careful about shorting a computer switched output to ground or directly to heavy load such as a fuel pump or fan motor.
Got it. Thank you. I JUST got to section three in Paul's book that covers this as well.
