15' Retractable Test Leads
8 years 7 months ago #19215 by Noah
15' Retractable Test Leads was created by Noah
The following user(s) said Thank You: Chad, Tutti57
8 years 7 months ago #19221 by Chad
Replied by Chad on topic 15' Retractable Test Leads
Nice! I just ordered 2 of them. B)
Thanks!
8 years 7 months ago #19256 by Tyler
Replied by Tyler on topic 15' Retractable Test Leads
I wonder why the maximum current changes? :huh: Heat buildup? RFI?
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 7 months ago #19279 by Dylan
Replied by Dylan on topic 15' Retractable Test Leads
Tyler wrote: I wonder why the maximum current changes? :huh: Heat buildup? RFI?
I'd say heat buildup. It's like a cable drum you use at home. On mine there's a max power for when it's rolled up or unrolled. There's also a thermal switch on it for safety.
8 years 7 months ago - 8 years 7 months ago #19281 by Tyler
Dylan wrote:
Tyler wrote: I'd say heat buildup. It's like a cable drum you use at home. On mine there's a max power for when it's rolled up or unrolled. There's also a thermal switch on it for safety.
Ugh, useless. If I can't jump all eight glow plugs with my test leads, then I don't need 'em! :silly:
:lol: But seriously, 10A isn't bad. I have a bad habit of jumping loads with my scope leads, then wonder why they get hot. :blush:
Last edit: 8 years 7 months ago by Tyler.
8 years 7 months ago #19285 by Ben
Replied by Ben on topic Re:15' Retractable Test Leads
These are very light duty excellent for resting continuity from front to rear of vehicle or light loads ,I think It said it was 18gauge which is not sufficient to carry 10 amps very long!
8 years 7 months ago - 8 years 7 months ago #19366 by Noah
Replied by Noah on topic Re:15' Retractable Test Leads
So I should unwind the reel before I jump start my truck with them maybe?
On a side note, just how much smoke do you think is in these things? They smell terrible during starter relay bypass testing...:pinch:
Last edit: 8 years 7 months ago by Noah.
8 years 5 months ago #20603 by Ephratah
Replied by Ephratah on topic 15' Retractable Test Leads
I have 2 of these and they are great I also bought a set of female connectors so I can string them together and have 30 feet of test lead nice to be able to hook up to scope and use the neg battery terminal for the ground
Hitting it with a Hammer is worth $5 knowing where to hit is worth $40
