Ultrasonic leak detector :-)
  • Andy.MacFadyen
8 years 7 months ago #19630 by Andy.MacFadyen
Ultrasonic leak detector :-) was created by Andy.MacFadyen
I bought a cheap ultrasonic leak detector to trace water leaks I am not 100% sure how good it will be for that kind of fault but I tried it on a couple of simulated manifold vacuum leaks and I am most impressed with the results.
8 years 7 months ago #19637 by Ben
Replied by Ben on topic Re:Ultrasonic leak detector :-)
How does it work?
  • Andy.MacFadyen
8 years 6 months ago #19652 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Ultrasonic leak detector :-)
The pack contains two units the first is is a receiver unit that has a microphone sensitive to ultrasonic sound and electronics that convert the ultrasonic sound into sound you can hear through headphones. With pressure leaks including vacuum leaks the rushing gas usually produces an ultrasonic whistle that humans cannot hear but if you use the ultrasonic detector you can hear the leak via the headphones and track it down by searching with the microphone.
For looking for a leak in say a tailgate rubber seal you also use the other unit which is an ultrasonic sounder inside the trunk close the tailgate down and with the reciever search around the tailgate seal and and other likely ares where rain could leak in.
8 years 6 months ago #19668 by Noah
Replied by Noah on topic Ultrasonic leak detector :-)
I've never seen such a tool! Cool stuff.
  • Andy.MacFadyen
8 years 6 months ago #19675 by Andy.MacFadyen
8 years 6 months ago #19689 by Genman
Replied by Genman on topic Re:Ultrasonic leak detector :-)
I have used these ultra sonic leak detectors in very noisy power plants to find small air leaks - they are perfect for all kinds of leak detection
Sent from my iPad using Tapatalk
8 years 6 months ago #19695 by JeffBirt
Replied by JeffBirt on topic Re:Ultrasonic leak detector :-)
What tool do you use to fix an ultrasonic leak? Any Dr. Who fans out there? :)
8 years 6 months ago #19700 by Tyler
Replied by Tyler on topic Re:Ultrasonic leak detector :-)
I've heard this type of tester is needed on newer EVAP systems during leak testing, as smoke is too difficult to see with extremely small leaks. B)
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 6 months ago #19708 by Dylan
Replied by Dylan on topic Re:Ultrasonic leak detector :-)
That seems like a pretty handy tool Andy. I need to talk to our service manager to buy one ;)
  • Andy.MacFadyen
8 years 6 months ago - 8 years 6 months ago #19713 by Andy.MacFadyen
I knew they worked but waited until I saw one at a bargain basement price. It surprise d me how well it worked on a vacuum leak.
I discovered it also picks up ultrasonic reversing sensors.
Last edit: 8 years 6 months ago by Andy.MacFadyen.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 6 months ago #19737 by Dylan
Replied by Dylan on topic Ultrasonic leak detector :-)
Andy.MacFadyen wrote: I discovered it also picks up ultrasonic reversing sensors.
Now that is interesting!
  • Andy.MacFadyen
8 years 6 months ago - 8 years 6 months ago #19740 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Re:Ultrasonic leak detector :-)
JeffBirt wrote: What tool do you use to fix an ultrasonic leak? Any Dr. Who fans out there? :)
Only since Novermber 23rd 1962 I watched the first broadcast of "An Unearthly Child"
other things sadder happened that weekend kind of an eventful couple of days.
