cheap Scan tool with activation
  • scopeman
  • scopeman's Avatar Topic Author
10 years 1 month ago - 10 years 1 month ago #2151 by scopeman
cheap Scan tool with activation was created by scopeman
Just like to share this scan tool for anyone who does not have a lot to spend and want bang for buck DS150E Equivalent Bluetooth Diagnostic Scanner OBD2+FREE WOW 5.00.8R2+car 2014r2
Got this last week and so far i am impressed .It works pretty well and has a actuate function option as well as graphing and coding .Does loads of manufacturers up to 2016 vehicles and has TSBS and wiring diagrams on the accompanying wurth wow dvd .Works via bluetooth or usb .Does have U.S vehicles as well . I did once try out the Autel MD802 Pro Maxidiag Elite ALL SYSTEMs scanner and the Ds150e has more capabilities .Obviously this won't beat some of the higher end stuff but this is great for the price .
Why does my ebay link not work when i add it here ?
Here is some info -
Clear instructions and video included on BOTH DVD's to allow easy set up.
Compatible with windows 7,8 and 10 also by copying the DVD content to USB drive, you can install it on Windows tablets too.
Here is a list of languages the 2014r2 software can support:
Bulgarian Bulgarski
Czech CESKY
Croatian Hrvatski
Danish Dansk
English
German Duetsch
Spanish Elspanol
French Francais
Greek Ellinika
Hungarian Magyar
Italian Italiano
Dutch Nederlands
Norwegian Norsk
Polish polskie
Portuguese Portugues
Romanian Romana
Russian Russkiy
Serbian Srpski
Finnish Suomen
Swedish Svensk
Turkish Turk
Here is the list of the Languages the WOW software can support:
Please ask at checkout for us to load the selected Language when ordering as these are not as standard On the WOW disk. Thank you. Otherwise you will need a new DVD sent out which may cost you extra.
English
French
Dutch
Italian
Czech
Portuguese
Turkish
Serbian
Russian
Polish
Hungarian
Greek
German.
Bluetooth Diagnostic Scanner (aslo works via USB)
DS150 Equivalent is a quick and reliable diagnostic tool serving as a link between vehicle and computer. It works on both old and new vehicles.(as long as OBD2 is on, compulsory from 2001 petrol and 2004 diesel)
The best scan tool available. Save thousands on dealer prices, Improved Chip set design with perfect communication to laptop and vehicle.
Dispatch from UK. No Customer Tax & Duty charge for EU Customers.
Just a few of the 100's of features....
FLIGHT RECORDER
With the flight recorder function, you can record parameters in real time while you are driving a vehicle. During recording, you can, with a press of a button, highlight the specific error so that you can investigate the detected error at a later time. TCS CDP+ is equipped with |SD card slot thus removing the need to bring a computer. Memory card not include in package .
MULTI COLOUR INDICATOR
With the multi colour indicator on TCS CDP+, you have full control of the diagnostic process. Different colors and sound communicates the status and the placement of the indicator allows you to see it from a far. For example, if the indicator alternates between blue and green the CDP+ is in communication with the vehicle control unit.
VOLTAGE CHECK
When TCS CDP+ is connected to the vehicle, the unit will check the battery voltage of the vehicle and automatically adjusts itself to the vehicle’s voltage level of 12 or 24 volts. If the voltage gets too high or too low, CDP+ will warn you with both sound and light and you will also be alerted through the battery icon in our diagnostic software.
CHASSIS NUMBER VIN
In our CARS software, we have a smart function that allows you to read out the chassis number from the vehicle that you would like to diagnose. This ensures that the right model and year is selected automatically. In addition, engine code for vehicles, which are commonly available on the markets, is also selected automatically.
ISS
Intelligent System Scan (ISS) scans through all the systems in the vehicle and displays the fault codes that are stored in each system. This saves time and you get a quick overview of the actual status of the entire vehicle. When the ISS is complete, you can then select a specific control system to analyse the results further on.
ISI
Intelligent System Identification (ISI) identifies and selects automatically the type of controller that is mounted in the vehicle. This ensures that the diagnostic session is performed correctly with the correct parameters as required.
REPORT FUNCTION
Under this function tab, you will be able to see the adaptations and adjustments that are possible for a specific vehicle without having the vehicle near you. Together with the help texts as a guide, you can plan and be effective in your work; even under complex situations.
OBD-FUNCTIONS
TCS CDP+ is equipped with an unique multiplexer technology, which allows it to be used on all types of vehicles, regardless of voltage levels and communication standards. For those vehicles that do not use the standard 16-pin connector, we offer a complete set of certified and customized adapter cables and kits.
UNIVERSAL
For most OBD functions, such as adjustments and programmings, there are detailed instructions and help texts to assist you in your diagnosis work. You will find step by step information about prerequisites, preparation and implementation of various functions; making even the most complex function simple to perform
HELP FUNCTION
For most OBD functions, such as adjustments and programmings, there are detailed instructions and help texts to assist you in your diagnosis work. You will find step by step information about prerequisites, preparation and implementation of various functions; making even the most complex function simple to perform.
1 x NEW VCI interface unit OBDII and OEBDll diagnostic scanner /bluetooth + usb/
1 x USB cable
1 x 16pin ODB2 plug
1 x DS-150 software DVD (2014 R2)
1 x WOW 5.00.8R2 software DVD
Last edit: 10 years 1 month ago by scopeman.
10 years 1 month ago #2165 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic cheap Scan tool with activation
Pirate copy of. Delphi DS150...........
  • scopeman
10 years 1 month ago - 10 years 1 month ago #2168 by scopeman
Replied by scopeman on topic cheap Scan tool with activation
Hi Andy,
Never heard of Delphi or the Ds150e before i purchased mine.Always looked at snap on or autel but the higher end models are quite expensive.
Just happened to see the Ds150e and thought i'd try it out.Was not expecting much for the money but was quite surprised at what it offers.As for pirated software not really sure if it is or not as it's sold on quite a few sites. Saying that Ford did try and sue Autel i think saying they were using pirated software for there products ? Also the hantek software is very similar to pico .Don't really know about this kind of stuff as i was just looking for affordable diagnostic equipment to learn with .Was just posting to let others know about the Ds150e that i got so people can have a wider range to look at that suits there budget and not think it has to be snap on or Autel .
10 years 1 month ago #2169 by Andy.MacFadyen
There is a huge difference between reversed engineering protocols and selling cracked pirate copies.
