Vantage pro Amp clamp
- Bigfoote13
- Thank you received: 2
8 years 2 months ago #22914
by Bigfoote13
Vantage pro Amp clamp was created by Bigfoote13
Greetings again, I was using my vantage pro for the first time the other day trying to get a 600 amp reading Of my starting system. I didn’t notice in the menu any selection for 600 amp testing. Only Low amp 20 - 40 Amp settings. Does it not read higher amps? Thank you for any suggestions. Doug
- Doodah14
- Thank you received: 6
8 years 2 months ago #22915
by Doodah14
Replied by Doodah14 on topic Vantage pro Amp clamp
The clamp is going to convert the reading into voltage. I don't know the exact conversion. It's like 100mv to 1 amp. Something like that. Set your scope to mv and play with the ranges. Someone here may know the exact conversion. That's what I had to donor my 400 amp probe.
- Bigfoote13
8 years 2 months ago #22919
by Bigfoote13
Replied by Bigfoote13 on topic Vantage pro Amp clamp
Thanks a lot I’ll try that!
- Bigfoote13
8 years 2 months ago #22922
by Bigfoote13
What initial setting do I use though?
- GypsyR
- Thank you received: 27
8 years 2 months ago #22973
by GypsyR
Replied by GypsyR on topic Vantage pro Amp clamp
Part of using a scope is tweaking the settings to clarify what you want to see. THere's a pretty good video from Wells Electronics on this on YouTube. Not using a Vantage but another scope. But they illustrate just throwing it on the car and then how to adjust things to turn whatever base settings they had into what you need.to get a reading you can make sense of.
In particular, I think I might start with a 0-5 volt scale.
- GypsyR
8 years 2 months ago #22974
by GypsyR
In particular, I think I might start with a 0-5 volt scale. (Hope the link works)
