Pico 2204a 2 channel scope suitable for cam & crank correlation?
  • toyota1990s
  • toyota1990s's Avatar Topic Author
8 years 4 weeks ago - 8 years 4 weeks ago #23694 by toyota1990s
Hello, Would the Pico 2204a 2 channel scope be ok to use for correlation between cam and crank sensors?
I already have the 1 channel Uscope with 10:1 attenuator and AC filter which is great for most things. I am on a limited budget and do not want the Pico for primary ignition or injector tests.
Thanks
Steve
Last edit: 8 years 4 weeks ago by toyota1990s.
8 years 4 weeks ago #23701 by Andy.MacFadyen
No problem you can use attenuators with the 2204a I have never used that model but I would assume it has a scale for the automotive 20:1 attenuator as well as the 10:1, 100:1 and 1000:1 used for more general use.
However I would try and stretch the budget for a 2205A
The following user(s) said Thank You: toyota1990s
  • toyota1990s
8 years 4 weeks ago #23724 by toyota1990s
Thanks for replying Andy. The price difference between the 2204a and 2205a is not a mile apart so i'll follow your advice and opt for the 2205a.
