Tapdon airdiag 900 lite
  • Jerry McGillis
  • Jerry McGillis's Avatar Topic Author
1 year 6 months ago #88606 by Jerry McGillis
Tapdon airdiag 900 lite was created by Jerry McGillis
When I go to the graph of the crankshaft sensor, the wave form is all over the place , it goes in sets of 3 , then there will be a 4 count and some time you get a 5 count
are they accurate or do you need a scope to read them ?
1 year 6 months ago #88664 by Noah
Replied by Noah on topic Tapdon airdiag 900 lite
Scoping the crank sensor is the most accurate way to check, but if the scan tool shows RPM and if the engine has spark, then that's a pretty good indication the crank sensor is working.
The following user(s) said Thank You: Jerry McGillis
  • Jerry McGillis
1 year 6 months ago #88670 by Jerry McGillis
Replied by Jerry McGillis on topic Tapdon airdiag 900 lite
The jeep does run, just got a miss fire when it gets to operating temp.
Been to (3) different shops ( one was a dealer) that say everything is working as it should. No one has an answer for the miss fire.
So I'am kind of on my own to find the problem.
Time to create page: 0.360 seconds
