Snap On EAC0056L03A COP/CIC pickup stick
- JTF010
1 year 1 month ago #92256
by JTF010
Snap On EAC0056L03A COP/CIC pickup stick was created by JTF010
I got a pick up stick and it worked on my nissan sentra but it doesn't work on some other cars. Is this tool limited to what it can be used on?
1 year 1 month ago #92257
Replied by Noah on topic Snap On EAC0056L03A COP/CIC pickup stick
Some ignition coils are just better shielded than others. Honda coils come to mind, they usually don't produce a good waveform with an inductive secondary probe but most from American brands work just fine. It's hit or miss, learn as you go.
The following user(s) said Thank You: Chad, JTF010
- JTF010
1 year 1 month ago #92258
by JTF010
Replied by JTF010 on topic Snap On EAC0056L03A COP/CIC pickup stick
ok awesome great to know, a hyundai and tacoma i couldn't so im curious if there are any from that manufacturer that would produce a waveform. would the secondary ignition clip on wire and rpm inductive pick up accessories work better or no? EETM306A02,EETM303A05A
1 year 1 month ago #92259
The best way I know of to obtain a secondary waveform on a well insulated ignition coil is to add a spark plug wire between the ignition coil and the spark plug.
I keep a handful of Chevy LS style plug wires for spark checking ignition coil cassettes like are equipped on some GM 4-cylinder engines. This way you can clamp right on the wire of the cylinder you want to scope.
The following user(s) said Thank You: JTF010
- JTF010
1 year 1 month ago #92263
by JTF010
couild you send a picture or link to a video? so i know what to do
