Chassis ear/ NVH
- Chriscoy
- Heavy duty truck technician / foreman/ parts guy/
- Thank you received: 6
Changing parts is easy, Troubleshooting is an art
- ScannerDanner
- Administrator
- Thank you received: 500
Maybe I'll get time to edit that one in the next few weeks.
But it will be with the pico NVH
Don't be a parts changer!
- Chriscoy
Not having a way to plug into the DLC means grabbing a crank sensor, and VSS pulse to tell the scope engine and vehicle speed. I'm down to get it a hell of a try, but I have not been successful in getting the idea sold.
I've spoke with one of the guys as AES about the incorporation of a J1939 DLC adapter and was told at this time there was no help on big trucks. And there should be. These guys spend 11hrs a day behind the wheel and a vibration or growl will drive these guys batty.
That's cool, I've always wondered if I could make a set up with knock sensors.Andy.MacFadyen wrote: I tried making an home built setup using cheap guitar pick-up contact microphones but it didn't work the scope didn't pick-up any signal.
ScannerDanner wrote: Got an NVH case study coming up on my Silverado. Had a vibration after lift kit install. I'm going to make it the final part to that series.
Awesome! :woohoo: I've been hearing a lot about this Pico NVH kit on AESwave and iATN, can't wait to see how it goes.
Noah wrote: That's cool, I've always wondered if I could make a set up with knock sensors.
That reminds me, I heard from a class recently about using a knock sensor to detect fuel injector problems... I have no idea if there's any merit to this concept, but I'm willing to try it!
EDIT
I found the guitar mikes this morning and tried again, something must have be wrong with the connection the last time as this time with the mike clipped to the injector body I got lots of signal but making sense of it is a different matter.
There is a visible difference with the injector disconnected but to be useful it would need synched to the ignition or an injector as there is a lot of echoes the other injectors.
Until I try synching it, adding a filter and getting that to work I can't see any advantage over using a stephoscope.
The idea of using a knock sensor might work better as it is designed to work on a narrower band of frequencies.
- maicsa2
Pico NVH video
Vibration App video
Andy.MacFadyen wrote: Until I try synching it, adding a filter and getting that to work I can't see any advantage over using a stephoscope.
Awwwww, sorry to hear that didn't work out!
I like the knock sensor idea, too. The only problem is most knock sensors are expensive-ish, at least $50. Not the worst gamble I've ever made, but not cheap, either
maicsa2 wrote: I'll be getting the NVH 4 axis kit in 3 days, I will post some pics here and a video on youtube! I can't wait to get it! I have already 5 cars waiting to be diagnose with this equipment, PICO is the best! John Kelly in the Weberauto channel in youtube has some very good info of the NVH from PICO and he has develop an app that uses the Iphone accelerometer for vibrations and so on, that is very impressive, a little pricy $400, but for those who can afford the whole Pico set up ( lap top, picoscope, NVh and some J2534), is great!
Pico NVH video
Please let us know what you think of the Pico kit!
I would love to play with that NVH app, too, but no Android support
I like the knock sensor idea, too. The only problem is most knock sensors are expensive-ish, at least $50. Not the worst gamble I've ever made, but not cheap, eitherThe last two knock sensors I replaced on the job were electrically open, so no luck there.
- Chriscoy
I'm no electronic guru by any means but my little brother is! Christmas is coming so... why not.
- Richey.brown
- Richey.brown
- Richey.brown
- Richey.brown
With it attached to a screw driver, is it good to id a noisy pulley, or is it to sensitive for something like that?
Chriscoy wrote: You guys are awesome. I never expected this post to branch off like this. But since it did... Me being a curious guy and such, I was poking around the Adafruit site and found a small accelerometer that I'm tempted to buy and hack into a cheap low tech Vibration detector.
Oh yeah, sorry man :blush: Didn't mean to hijack your thread!
- Richey.brown
