Frequency test gm MAF
  • Toolman10000
  • Toolman10000's Avatar Topic Author
7 years 5 months ago #29854 by Toolman10000
Frequency test gm MAF was created by Toolman10000
I’m trying to get a reading off of a MAF on a 2006 Chevy Silverado. I’ve tried sensor ground and battery ground. Sensor ground is a little cleaner. I can’t get a nice smooth reading. All the way through it I have these spikes that spike well above 50 kHz. I’m not sure what’s going on. Am I picking up interference ? I get the same thing on my 6.7 ram.
  • Toolman10000
7 years 5 months ago #29855 by Toolman10000
Replied by Toolman10000 on topic Re:Frequency test gm MAF
Here is a pic.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
7 years 5 months ago #29859 by cheryl hartkorn
Replied by cheryl hartkorn on topic Frequency test gm MAF
whats scan data say? same thing vs scope?
  • Toolman10000
7 years 5 months ago #29919 by Toolman10000
Scan data is normal. Can only get 7000hz on a snap throttle. Code P0101 comes up intermittently.
  • johnathon.balderas
  • johnathon.balderas's Avatar
  • Stay humble and thank God everyday for waking up.
7 years 5 months ago #30195 by johnathon.balderas
Replied by johnathon.balderas on topic Re:Frequency test gm MAF
So you are getting 50khz spikes, even on your dodge?
7 years 5 months ago #30196 by johnathon.balderas
i think i see your problem. It looks like you have peak detect on. when i first did this test i had peak detect turned on and experienced the same issue. im pretty sure this when doing this test peak detect should be off. maybe some of the more experienced scope users can chime in.
7 years 5 months ago #30197 by johnathon.balderas
Nevermind peak detect should be on its the filter i was confused about. Im mixing up the filter and using peak detect
7 years 5 months ago #30211 by Noah
Replied by Noah on topic Re:Frequency test gm MAF
did you try a shorter time base? 10 seconds might be a bit long to capture the detail you're looking for
