Ref. voltage sensors wire check
- derekoliveira
Thank you
- OBD Rick
- Thank you received: 10
Calling upon my years of experience, I froze at the controls. – Stirling Moss
Also, if the wires are the same color on each sensor, it's a good indication that they all share the same source.
I suppose you could use an ohm meter it you disconnected two of the sensors in question and placed one lead on each 5v feed. Like you said, key off of course. I've never tried that, but I imagine you'd want to see very little or no resistance.
Good point!OBD Rick wrote: Hi Derek, the best idea would probably be to find a wiring diagram for your vehicle, this way you don’t risk leaving a sensor or module plugged in that may get damaged in the process
I hadn't considered that.
- Dylan
- Belgium, Europe
- Thank you received: 327
- derekoliveira
Tioretically speaking or not
There are many ways to Rome, if you now same of them is much better
Thanks
- Eddie daGrouch
- Tinker 2nd Class
Toners come in analog and digital and I have used them with great success in electrical, networking, and automotive use.
With the Hoopty-Clip® you simply jumper your reference wire to ground and poke around with an ohm meter looking for similar readings. The idea is to change a bias string to a value that sets it apart from the rest. Each sensor has it's own internal resistance but they are typically higher - the lower jumper resistor will limit current (if you need to work live for some reason) and swing the whole chain low enough to tell the bias lines apart. If you get a near zero ohm reading you need to find the pinched wire or shorted sensor.
If the PCM pulls the bias lines to ground with key-off you'll need to disconnect the PCM as toners can't work with a short to ground. If you do that anyway you can forgo the resistor or toner altogether and just jumper the bias line to ground (after checking for shorts). If you make a few jumpers, each with a different value, you can clip one to each bias line and quickly map them out with a test light going by the intensity using the PCM or an external bias voltage supply.
Grouchy
Remember to rotate your spark plugs every 3,000 miles.
- derekoliveira
- Interrupt
The 5v ref with test light to batt neg and the return path to bat + that way you load the wiring and I find much more reliable then a continuity testing..... all you need is one strand of copper in a otherwise broken or rotten wire to return a positive result!
(I normally use a beef bulb like a headlight bulb/21W for a bit more load) OBVIOUSLY Making sure not to over load the circuit!
(I've never used a tone tester but I imagine the same would be true?)
- OBD Rick
I can't really think of one,I can understand the frustration, looking at mitchell diagrams on Paul's videos then going back to my ancient copy of autodata off a CD sucks...
- Interrupt
Sorry ignore me, I read the bit about the 3 or 4 dtc's and went on a tangent!!derekoliveira wrote: Good night, ok the "problem" is european digrams are a little bit incomplete...they give you colors, but they don t tell you or show you internal connections. Can you trust on colors 100%? In my opinion, no!!!
Tioretically speaking or not, if you have a car with a 3 or 4 dtcs related with with engine sensors and you don t have the wiring diagram. So if you find out and make shore they are related, you are 1/2way
Thanks
- derekoliveira
- Interrupt
If you worried about doing damage with a test light don't (i've even shorted the 5v ref circuit to ground :whistle: by accident with no ill effects.....but don't try this at home it could go very bad )
I would start with a normal test light that draws 100ma - 250ma, you can connect the multimeter at the same time to measure to voltage drop while the circuit is loaded!(I wouldn't expect the voltage to drop below 4.5v from 5v at this load....probably less )
You could disconnect the ecm and all sensor and then continuity test between one of the know sensors with a fault code at the ecm plug (you would have to disconnect or there could be a chance (small)of a false read via a component in the ecm or sensor) once you've established 5v ref and return path at the ecm plug for that sensor then check for continuity with the other sensors with fault codes to confirm common references wiring......but in my mind that's hard work....as Paul says it's not the next easiest step!!!
If I didn't have a reliable wiring diagram the test light route is how I would tackle it!
- derekoliveira
Thank you for helping me!
- RR-Auto
