Diagnostics Scanner
  • randy61
  • randy61's Avatar Topic Author
7 years 2 months ago #32826 by randy61
Diagnostics Scanner was created by randy61
What type of scanner is there that does NOT have to be connected to the OBD port connector in order to read sensors, fuel trims and injectors?
  • randy61
7 years 2 months ago #32827 by randy61
Replied by randy61 on topic Diagnostics Scanner
randy61 wrote: What type of scanner is there that does NOT have to be connected to the OBD port connector in order to read sensors, fuel trims and injectors?
7 years 2 months ago #32832 by Noah
Replied by Noah on topic Diagnostics Scanner
A scanner, by definition must be plugged into an OBD port.
OBD standing for on board diagnostics.
after 1996, US vehicles adhere to OBD2 protocol and have a standardized OBD port.
Older vehicles have non standardized ports for factory level scan tools.
So every scanner needs to be plugged into an OBD port, even if it is not the standard plug that we recognize today.
Many scan tools have adapters to connect to pre OBD2 vehicles (snap on , launch, Bosch), but I have very seldom had the need to use them and any time I have, the data and codes available were severely lacking in providing diagnostic direction.
The following user(s) said Thank You: randy61
7 years 2 months ago #32833 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Diagnostics Scanner
Pre OBD2 it was OBD1 and by legal requirement all that was stored was a few very general fault codes that were manuafacturer specific, there was no requirement for live data from sensors
The following user(s) said Thank You: Noah, randy61
  • randy61
7 years 2 months ago #32843 by randy61
I have a 1990 jeep Cherokee which it is pre obd. No codes or any data storage. So basically I would have to rely on a DMM... correct?
7 years 2 months ago #32844 by Andy.MacFadyen
  • randy61
7 years 2 months ago - 7 years 2 months ago #32860 by randy61
The 90 Cherokee computer does not store or throw codes. It is not OBD1 or 2.
There are no flash codes either. That only worked with newer Cherokee's after 91.
That is a big misconception going around on the internet that flash codes can be had by turning key on and off for 87-90 Cherokee's.
Last edit: 7 years 2 months ago by randy61.
  • randy61
7 years 2 months ago #33077 by randy61
I watched scannerdanner testing an intermittent stall, no start -po320, p1391 cam, crank sensor testing (jeep)
His Veris scope wasn't attached to the obd port.
It was attached to the battery terminals and to the sensor wires for a square wave signal between the cam and crank sensors.
So why is it not possible to run a scope on the 1990 jeep Cherokee?
7 years 2 months ago #33079 by Noah
It is possible to use a lab scope on your Jeep!
While it just happens to be built into the Verus, it is not typical to have a lab scope and scan tool combo, they are two very different tools.
A scope will not provide you with trouble codes or data pids. It is essentially a very fast multi meter that you can use to verify circuit integrity and sensor signals. However, without a frame of reference, the most you can do is verify that a sensor is doing "something".
Luckily for you, you have material to reference!
If you have a scope, the tests that Paul demonstrates on his Jeep should be valid for yours.
  • randy61
7 years 2 months ago #33081 by randy61
Noah wrote: However, without a frame of reference, the most you can do is verify that a sensor is doing "something".
Can you elaborate further regarding?
(without a frame of reference),
(you have material to reference!)
7 years 2 months ago #33088 by Noah
What I meant was that if you wanted to perform the same test as in the video, you know what results to expect having seen the tests performed already.
Where as if you suspected say a coolant temperature sensor issue for example, you couldn't just back probe the sensor with a scope and say it's X degrees. Instead you would need to know what voltage correlates to what temperature and determine if it's reporting a reasonable value.
If you had access to scan data, you could scroll through the data pids and see exactly what temperature the computer is inferring from the sensor signal.
Just like your cam and crank signals. On OBD 2 Chrysler vehicles (Jeep included), there's data pids that indicate the presence of cam and crank signals and if they're in sync.
With a scope you would need to capture the signal waveforms, verify that they are within specific voltage range and compare to a known good vehicle to know if there was a synchronisation issue.
Hope that makes sense :)
