Transponder key testers?
  • Cheryl
  • Cheryl's Avatar Topic Author
7 years 2 months ago #33280 by Cheryl
Transponder key testers? was created by Cheryl
Does anyone have any testers to test if the transponder is good in a key? I am working on a Ford F-150 and getting a b1681 and don’t want to drop money on keys and don’t fix the issue plus I’d be able to add to my tools I already have
7 years 2 months ago #33293 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Transponder key testers?
I haven't seen anything that checks the response from the transponder chip but I have the tool that checks if the coil round the key barrel is transmitting when a key inserted
www.scannerdanner.com/forum/diagnostic-t...-purchase.html#23557
The DIY version is wrap a few coils of fine wire round the key and connect one end to scope + the other to ground with a fast screen you should see the coil on the car transmitting.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
7 years 2 months ago #33349 by cheryl hartkorn
Replied by cheryl hartkorn on topic Transponder key testers?
i have that same tool i used it on a 2004 f150 inserted key turned it led flashed okay cool tranciever is good. led me on a chase. it ended up being a bad ground at the module that goes around the lock cylinder.
