Old Modis scan tool
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
7 years 3 weeks ago #34105 by Mechanic 350
Old Modis scan tool was created by Mechanic 350
Has anyone had the problem with this particular scanner? Trying to measure voltage, going into the multimeter section and the lab scope section, I can't seem to get readings of voltage not even in my car battery. has anyone had any trouble with this? My scan tool is completely out of date, but that shouldn't affect the lab scope features right. In addition, the ohms test feature, touching the wires to zero out the reading, I can't get it to even do that. I guess time for another scan tool/labscope. used of course. any recommendations. I a diyer mechanic.
7 years 3 weeks ago - 7 years 3 weeks ago #34107 by Noah
Replied by Noah on topic Old Modis scan tool
If there's no trace going across the screen, try the "power off" tab at the top right corner of the screen.
It should still keep you in the labscope display screen. Then, in the bottom left use the "record" tab. It's just a red circle that will change to a "pause" icon (II) when recording.
Then you should hear the clicking and ratchet sounds inside the machine as the scope wakes up.
I have to do this with my first gen Verus (which I will be selling soon) from time to time.
Hope that helps, keep us posted
Last edit: 7 years 3 weeks ago by Noah.
Time to create page: 0.247 seconds
