wideband o2 sensors on my BMW.
  • steve86
  • steve86's Avatar Topic Author
6 years 11 months ago #34976 by steve86
wideband o2 sensors on my BMW. was created by steve86
Hi all,
I have a BMW e92 2.0l car, living in the UK. I've been trying to get my head round how the wideband sensor works. I have 2 banks with pre and post o2's on both banks. I've noticed that the post bank o2's are a 0 to 1 volt and I'm guessing that these are narrow bands. They seem to be mirroring the widebands at rich and lean. Is this normal or should they be steady mid range with adjustments with lean and rich conditions confirming good cat operation. I hope this comes across clear. Thanks.
Steve
  • steve86
6 years 11 months ago #34981 by steve86
Replied by steve86 on topic wideband o2 sensors on my BMW.
Apologies if I have posted this in the wrong section.
6 years 11 months ago - 6 years 11 months ago #34985 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic wideband o2 sensors on my BMW.
Unless you really max out the fuel trims rich or lean artificially you shouldn't see as much change in the post cat O2 sensor with a wideband upstream sensor compared with a normal Zirconia sensor wideband Titania sensor output works in the opposite voltage way round.
Although it won't confirm calibration accuaracy Wide band sensors keep pretty close control of the air-fuel ratio, the usual quick test on a wide bad sensor is what I call the "Dippsy Doodle Test"that is to quickly floor and instantly release the throttle pedal.
You should see the air fuel ratio instantly spike rich (low voltage) and when the pedal is released go instantly and very briefly lean (high voltage) then very quickly damp down to stochiomectric. The recover time to settle back to stoichiometric varies between manufacturers and models.
Unless you artifically introduce extra fuel or introduce a vacuum leak effect on the downstream sensor should be not as pronounced compared with a conventional narrow band upstream sensor.
Last edit: 6 years 11 months ago by Andy.MacFadyen.
The following user(s) said Thank You: CurrentDraw
  • steve86
6 years 11 months ago #34986 by steve86
Hi Andy,
Thank you for your reply and information you have provided, very grateful. So my downstreams follow rich and lean with the upstream's but in opposite voltage, equalling defective cats. Am I correct?
Many thanks.
Steve.
6 years 11 months ago #35023 by Andy.MacFadyen
Yes rich and lean are reversed from what a conventional O2 produces but as with old style sensor.because the cat stores oxygen there should be a distinct time delay between forcing the upstream rich or lean and the change reaching the downstream sensor.
6 years 11 months ago #35024 by Andy.MacFadyen
I haven't the SD book to hand but it is well covereed in the book and there is a good video on the cat reserve oxygen storage test.
  • steve86
6 years 11 months ago #35106 by steve86
So just to confirm, am I right in thinking that I should be seeing the downstream o2's pretty much near stoic (straight line) with adjustments to rich and lean?
