Can you use MAP gas instead of Propane for vacuum leaks
- wdemr
6 years 5 months ago #39960
by wdemr
Can you use MAP gas instead of Propane for vacuum leaks was created by wdemr
I was wondering if you can use MAP gas instead of propane to test for vacuum leaks?
Not looking to explode the top end while checking.
Thanks in advance,
Bill
Thanks in advance,
Bill
6 years 5 months ago #39980
Replied by Andy.MacFadyen on topic Can you use MAP gas instead of Propane for vacuum leaks
Increase risk of pre-ignition and higher combustion temperature ... I really don't know
6 years 5 months ago #39983
Replied by Noah on topic Can you use MAP gas instead of Propane for vacuum leaks
I have used map gas with mixed success as an alternative fuel source but haven't had the chance to try it on a vacuum leak yet.
Time to create page: 0.266 seconds
