What settings when testing secondary ignition using Own VDS1022I and Hantek HT25
  • GroundLoop
  • GroundLoop's Avatar Topic Author
6 years 4 months ago #40508 by GroundLoop
Have an issue with an 1987 Buick Grand National that I thought was fixed but it is still there. www.scannerdanner.com/forum/post-your-re...-no-codes.html#34089
Purchased an Own and Hantek probe. I have:
Timebase = 20ms / div
Channel 1 connected to the CAM HI pin on the ECM set to 5V / div. This comes from the ignition module. Waveform looks consistent
Channel 2 is connected to the Hantek ignition probe on cylinder 2 set to 500 mv /div
Channel 1 looks to my untrained eye to be good. It is a steady constant signal.
Channel 2 looks like there are some major issues.
Are these the correct typical settings. The output file from the Owon is a .CAP. Cannot attach it.
Thanks!
6 years 4 months ago #40525 by Tyler
Can you send me the .CAP file? wrenchturnsyou@gmail.com
I have no hands-on experience with those probes, but my first instinct is that the polarity may not be correct. Can channel #2 be inverted?
You may have thought of this, but I'd try hooking up to a known good cylinder first, for a baseline.
  • GroundLoop
6 years 4 months ago #40548 by GroundLoop
I did not try a known good cylinder yet. Will do that ASAP.
The channel can be inverted.
Sent you the file.
6 years 4 months ago #40562 by Tyler
Is there a preferred program for viewing .CAP extensions? :huh: I tried a couple, and couldn't make it happen.
6 years 4 months ago - 6 years 4 months ago #40579 by John Curtis
Capacitive pick-ups by design, will show an inverted waveform no matter how you clip it. By inverting it in the software, it becomes right side up
Last edit: 6 years 4 months ago by John Curtis.
  • GroundLoop
6 years 4 months ago #40599 by GroundLoop
Sent you an email with the link to the software for the Owon.
6 years 4 months ago #40600 by Andy.MacFadyen
Nearly always but it depends on coil polarity not all systems give the classic negative spark.
