Autel MS906TS
- kennyb
6 years 3 months ago - 6 years 3 months ago #41476
by kennyb
Autel MS906TS was created by kennyb
I just recently purchased an Autel scanner MS-906TS. I'm trying to figure out if I can look at the firing line in parade fashion with the oscilloscope.
I've only been able to look at each firing event separately I want to get all of them lined up on my screen in a row.
Is this possible with an Autel scanner?
Last edit: 6 years 3 months ago by kennyb. Reason: typo
6 years 3 months ago #41478
Replied by Tyler on topic Autel MS906TS
Hey kennyb! I moved this into the Tool section.
Unfortunately, the MS906TS does not have an oscilloscope. Thus, you won't be able to look at secondary ignition patterns.
You MAY be able to use the Autel MP408 scope kit with your MS906? I've only ever seen it used with the MS908.
- Matt T
- Thank you received: 276
6 years 3 months ago #41480
by Matt T
Replied by Matt T on topic Autel MS906TS
If you do have the 408 the ignition preset will probably set the horizontal time divisions so you can see one ignition event in detail. To see more of them on one screen just increase the H/div until you get what you want, though doing that may make it difficult to actually see the firing lines.
And that'll only work if you're 'scoping a distributor coil lead. If you're dealing with wasted spark or COP you'll need one channel per coil to get what you're wanting to see.
- kennyb
6 years 3 months ago #41487
by kennyb
Replied by kennyb on topic Autel MS906TS
Thanks for the reply. Yes I have the MP408 oscilloscope setup. I'm new at this, should have gotten a Snap On instead. Wish there was a video on this, guess I will have to experiment!
6 years 3 months ago #41490
Oh OK, cool!
Like Matt T asked, which vehicle did you want to get a parade pattern from?
kennyb wrote: Thanks for the reply. Yes I have the MP408 oscilloscope setup.
Oh OK, cool!
- kennyb
6 years 3 months ago #41494
by kennyb
Well, I've been watching Scannerdanner use the old Sun Scope and he is able to see ignition waveform on all cylinders on the screen then he does a snap throttle to look for problems. I'd like to be able to do this on any car with my Autel scantool. I guess I could start with my 2001 Honda Civic.
6 years 3 months ago #41498
Gotcha. Unfortunately, my experience has shown me that there's nothing quite like one of the old Sun machines.
There's really no equal, IMO.
It gets worse because Honda coils are not very secondary ignition friendly. :silly: Most probes, like the Pico TA204 and the AESWave Paddle Probe, won't get you a usable signal. I've tried.
That's not to say it can't be done. We've got several threads around here about making your own secondary probes. Definitely worth reading:
www.scannerdanner.com/forum/lab-scope-di...need-to-buy-one.html
www.scannerdanner.com/forum/diagnostic-t...secondary-probe.html
www.scannerdanner.com/forum/lab-scope-di...condary-paddles.html
- kennyb
6 years 3 months ago #41519
by kennyb
Ok wow thank you so much for your input!
