Any members ever use a sensor simulator/emulator
9 years 8 months ago - 9 years 8 months ago #5622 by Mugsy
Wondering if anyone has used a sensor emulator such as the D'land SSX. I purchased one a few weeks back and it seems like a handy tool to add to the arsenal. It will replicate TPS, MAP, MAF, O2, CAM, Crank, Hall Effect, positive/negative coefficient thermistors, and more. You would disconnect sensor from harness then inject the signal in the harness and watch the scope to see if the pcm responds positively. Has potentiometers for variable resistance, and voltage. Anyway just curious if anyone has had any experience with one.
"Only a handful of people in the world can do what we do."
Last edit: 9 years 8 months ago by Mugsy.
9 years 8 months ago #5651 by Noah
Seen 'em, never tried one. Be sure to let us know how it works for you when you need it.
9 years 8 months ago #5666 by Tyler
I've never used one, but I love the look of that SSX. :ohmy: Do you have a link to a retailer?
The closest thing I've used to a simulator is a variable resistor , for those times that I needed to test module response to varying signals. Also handy for manually bypassing GM Passkey systems. ;)
9 years 8 months ago #5682 by Mugsy
No eBay APP ID and/or Cert ID defined in Kunena configuration
Here is the link to the D'land SSX sensor. I purchased mine on ebay from Argentina. It is a well made unit!
$200 + $45 to ship to the us.
9 years 8 months ago #5684 by Mugsy
Let's try this link. Sorry, i'm a newbie. I'll get it at some point.
9 years 8 months ago #5685 by Mugsy
One last time my friends. Maybe I did it right this time.
9 years 8 months ago - 9 years 8 months ago #5688 by Tyler
Yeah, it really doesn't like that Ebay link, huh? You're not doing anything wrong, I just tried posting the same link. :unsure:
This was the only way I could get the link to stay:
Code:
http://www.ebay.com/itm/Automotive-Sensor-Simulator-Tester-CKP-TPS-MAP-MAF-ECT-IAT-CMP-VSS-O2S-Emulator-/322420345386?hash=item4b11c00a2a:g:jZ8AAOSwEeFU8xxp&item=322420345386&vxp=mt
I'll ask onyx about this, maybe the forum blocks Ebay links?
Last edit: 9 years 8 months ago by Tyler.
9 years 8 months ago #5689 by Mugsy
Anyway here is the item # 322420345386
or just search: SSX sensor simulator
and it should come up.
Sorry about all these attempts. Just trying to help.
9 years 8 months ago - 9 years 8 months ago #5690 by Tyler
No problem! Sorry for the trouble :blush:
