tps sensor testing on drive by wire
  • spit64
  • spit64's Avatar Topic Author
5 years 8 months ago #46746 by spit64
tps sensor testing on drive by wire was created by spit64
I tested a TPS sensor drive by wire with key on engine off.... the waveform did not move a lot one signal was 3.8 volt and the other 1.1 volt..... ignitions on were 4 volt and 0.9 volts. Is this the right way to test drive by wire or should the engine running
5 years 8 months ago #46764 by JJJ DA
Replied by JJJ DA on topic tps sensor testing on drive by wire
which vehicle are you testing? just to get the tps wiring diagram to understand how it works. with key on engine off you should read in engine ecu live data % tps or tps voltage. any dtc? thanks
  • spit64
5 years 8 months ago #46772 by spit64
Replied by spit64 on topic tps sensor testing on drive by wire
It is a TPS drive by wire on any car I was interested in if it is different ways to test them the car I test is the 5-volt ref and two potentiometers each have their own ground KOEO it is barely any response on older cars I only tested them with KOEO I have a thread on an Opel in the repair forum with Pico files
  • spit64
5 years 8 months ago #46775 by spit64
The throttle plate will not move a lot KOEO it took a waveform running big difference.
If you are interesting take a look at Opel fuel trims in the repair forum
5 years 8 months ago - 5 years 8 months ago #46852 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic tps sensor testing on drive by wire
I usually just use live data on drive by wire pedals and look for the two channels smoothly mirroring each other with a range roughly
1v to 4v to 1v
4v to 1v to 4v
Last edit: 5 years 8 months ago by Andy.MacFadyen.
  • spit64
5 years 8 months ago #46861 by spit64
Andy.MacFadyen wrote: I usually just use live data on drive by wire pedals and look for the two channels smoothly mirroring each other with a range roughly
1v to 4v to 1v
4v to 1v to 4v
Is this with KOEO I think it is strange that the throttle blade does not move with the ignition on engine off
5 years 8 months ago #46900 by Andy.MacFadyen
The thing is the pedal postion requests how the much power it how much the driver wants from the engine to the ECU but decides when to activate the throttle and what position it wants the throttle butterfly to be in.
